A couple weeks ago I noticed the TCC engaged a bit firmer than usual followed by a hesitation feeling that felt like a misfire. I then went and bought a set of new plugs thinking the ones in the motor was going bad. Fast forward a few days ago I was driving and planning on changing the plugs and the DTC 0742 light came up and the car lost power and worse if I was at a stop. Shifts were barely noticeable.
Monday I called the local trans shop I tend to go to (they did the trans swap when I had my built trans a few years ago) to drop the car off and have them drop the pan. On the way to the trans shop (3 miles), another DTC came on which was 0756 came. Just got the call from the shop and the tech said they found a lot of metal shavings and an overhaul is needed or a replacement trans. he said an overhaul, depending if the cooler lines need replacement as well, would be above the 2500 mark but they tend to shoot higher than estimate the price lower. So he said it’d cost 2K-2500. He also mentioned they can get a replacement trans but would cost the same about.
What’re my options? The car’s become more of a beater if anything so I’m debating to keep it and find a used trans on my own that I can get lower and have them swap the trans or have them do the overhaul or replacement trans and pay the 2000-2500? The other is find a used trans and supply it to them to install and sell the whole car for like 1700 (needs some TLC like driver side tie-rods, zip-tied front bumper, no AC, rocker panel is developing rust).
