Thread: Ok can someone clear this up for me?
Results 1 to 7 of 7
  1. #1 Ok can someone clear this up for me?
    Mar 2015
    wisconsin
    So I had a series 2 l67 I believe in my 97 gtp.
    I cracked a piston and it's garbage. I bought a new motor from a 2004 grand prix gt. Which 3800 motor would that be? I'm confused is it the l26, or l32?
  2. #2 Re: Ok can someone clear this up for me?
    Mar 2015
    Calgary
    If you purchased an N/A engine from a 2004 GT (7th gen Grand Prix) you would have an L26. The Supercharged variant was the L32.
  3. #3 Re: Ok can someone clear this up for me?
    The Boss Iceman6669's Avatar
    Jun 2011
    If it has a blower it is the L32, No blower L26.
    2011 F-150 Yote powered
  4. #4 Re: Ok can someone clear this up for me?
    St. Louis
    And if you plan on installing all the heads/blower setup from your trashed 97 motor you will have what is known as a "top-swap" and will have to do a few things to make it run right w/o blowing it up again.
    Might I inquire how you chipped a piston? Any mods done to the 97? Just trying to save you some future headache is all.
  5. #5 Re: Ok can someone clear this up for me?
    Mar 2015
    wisconsin
    I blew a head gasket and it leaked into my walls and one day I used water instead of coolant. I had a 3.5 w tstat. Zzp pcm and that was it
  6. #6 Re: Ok can someone clear this up for me?
    St. Louis
    It's pretty hard to blow a HG on these motors. I wonder if the LIM gaskets didn't let go instead. Either way, it's toast now. Do you run 91+ octane fuel? Do you have a way to scan for KR? If not, I'd suggest you get one so you don't blow the next one up. These cars knock stock, and a 3.5 on stock is probably not the best idea. And find someone who can tune it with HPT or the like. Likely you are leaving a bunch on the table with the canned ZZP tune.
    Also, take a read through this thread as it will help inform/guide you through modding it properly--> http://www.grandprixforums.net/threa...00-Powered-Car!!
  7. #7 Re: Ok can someone clear this up for me?
    Mar 2015
    wisconsin
    I always run premium. Do you think a 3.8 would be okay on a top swap l26 with sd headers colder plugs tstat and a tune?
  1. Is this clear coat?
    By PioneerGTP in forum Visual/Body Modifications
    Last Post: 10-04-2012, 10:35 PM
  2. clear reflector for clear corners?
    By ndgprix in forum Visual/Body Modifications
    Last Post: 03-26-2011, 10:55 PM
  3. where to buy new clear corners
    By nascartech in forum Off Topic Discussion
    Last Post: 02-12-2011, 01:12 AM
  4. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
