Thread: pcm resets when i turn car off
Results 1 to 10 of 10
  1. #1 pcm resets when i turn car off
    Mar 2015
    arizona
    ok so I have a 2005 grandprix the car needs to pass emissions but there is a problem every time I turn the car off the pcm resets
    and I have to start the drive cycle all over again.
    I have never had any problems with this car until now any help will be greatly appreciated thanks.
  2. #2 Re: pcm resets when i turn car off
    So the ready tests for like o2 sensors, evap and everything start over?
    I think thats normal though.
  3. #3 Re: pcm resets when i turn car off
    Jul 2010
    Coquitlam,BC,Canada
    You have to go for a long drive for the monitors to run their cycle. I had to wait for 2 days, which is about 120 km (50ish miles).
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: pcm resets when i turn car off
    Mar 2015
    arizona
    I understand that i ran the car until all monitors were ready. Once everything was ready i took the car to emissions then they turn the car off and back on all the monitors reset meaning they were not ready.
  5. #5 Re: pcm resets when i turn car off
    you have a scanner or t app to show you that they were ready? and then they reset afterwards?
    those things take a long ass time to all become "ready", hell my evap just took 3 weeks. and its codes are deleted lol
    t app readiness scanner thing. this dont happen in one drive.
  6. #6 Re: pcm resets when i turn car off
    Mar 2015
    arizona
    yes I have a snap on scanner I drive the car around 65 miles until they all become ready the only one that takes longer is the evap but here in Arizona you can have one not ready
    anyways when I turn the car off after a drive and turn it back on the car acts like if you disconnected the battery by resetting the pcm
    I unplugged a sensor to get the check engine light on and once I turn the car off the check engine light gets reset
  7. #7 Re: pcm resets when i turn car off
    only thing i can think of is the pcm is loosing power when the cars off. you'll need to dig up a pcm plug pin out diagram and see if its getting steady power key off.
    no need to dig, i found it for ya. http://www.grandprixforums.net/threa...60-PCM-Pinouts
  8. #8 Re: pcm resets when i turn car off
    Mar 2015
    arizona
    Thanks scotty for those diagrams i got a friend of mine to help me out and the pcm was not loosing power. So we decided the problem was the pcm. Bought a new pcm from the dealer and got it reprogramed and that fixed the problem. Passed emissions without a problem now.
  9. #9 Re: pcm resets when i turn car off
    sounds good.
    i hate to ask or even think what a dealer charges for a pcm and programming it.
  10. #10 Re: pcm resets when i turn car off
    I bet a reflash of the old PCM would have fixed the issue.
    It's not that the computer was even bad really, it still ran the car and performed just fine from the looks of it. Just that it didnt remember certain things. A updated relash likely would have fixed any problems.
  1. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  2. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  3. Dash/Raido Resets When Turning - 08 Base Model
    By Nic8524 in forum General Grand Prix Discussion
    Last Post: 05-13-2012, 04:56 PM
  4. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  5. Random PC resets
    By Xorbex in forum General Tech Discussion
    Last Post: 09-15-2010, 12:35 PM
