Simple question here - I am changing the valves in my GTP, they all got bent. Can I take the valves from a set of N/A heads, and drop them into the supercharger heads - or are they different valves?
Also, when the valves hit the pistons, there was a small chunk taken out of each one. I am thinking I can just grind down the sharp points with a dremel and the pistons should be just fine, they should be thick enough for a small nick not to matter... Does anyone have any input on this? From what I understand the biggest threat is pre-ignition, however I also don't want a hole being burned though the piston over time...
