Thread: Driver Information Center Woes
Results 1 to 3 of 3
  1. #1 Driver Information Center Woes
    Sep 2014
    South Carolina
    So I've purchased a couple GTP DICs. Out of 4 only one of them shows Performance Shift when it is turned on. The others have the spot on the LCD but won't turn on. The problem with the one that does show it is that the bulbs for the LCD will not turn on and I've tried bulbs that work in other DICs. I've put a GT DIC in and it shows everything but of course it turns my traction control off on start up.
    My questions are:
    Is there a wire I can move to make the other DICs show performance shift?
    Is there a way to fix the backlight on the one DIC that does show performance shift?
    If not, then is there a way to get the GT DIC to not turn TCS off.
    I've searched around on here and haven't found much about either subject.
  2. #2 Re: Driver Information Center Woes
    Is this for the 99 in your name?
  3. #3 Re: Driver Information Center Woes
    Sep 2014
    South Carolina
    Yeah this is for that one.
    Gen V M90 | 3.2" Pulley | N* Throttle Body | ZZP SSIC | S1X Blower Cam | INTENSE SIII Heads | 42# Injectors | Pacesetter Headers | Aluminum Subframe | ZZP Lowering Springs | KYB AGX Struts
  1. Driver information center! Please help!
    By ricio1991 in forum 04+ Specifics
    Last Post: 04-28-2016, 03:44 PM
  2. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  3. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  4. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
