Thread: Lim job
Results 1 to 15 of 15
  1. #1 Lim job
    Sep 2014
    chicago
    I'm trying to lift this lim up but it's not budging... Are there any hidden bolts or nuts I don't know about on the l67?
    My injector holes are filthy. So are the injectors.
  2. #2 Re: Lim job
    Donating Users timboku's Avatar
    Montgomery, IL
    Well you have two limited bolts still in from your picture.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: Lim job
    Sep 2014
    chicago
    Yea I found it, it was the first bolt to your left in the picture. Thanks. Had a lot of gunk covering it. Looks like coolant and oil was mixing into the exhaust port if I'm not mistaken.
    These are the only 2 ports with that milky sensation.....
  4. #4 Re: Lim job
    There are no exhaust ports there. The intake ports are the large black ones with carbon built up all over and you can see the valves.
    The picture that you circles are just coolant ports, and yes the LIM failed and the dexcool coolant turned to sludge on you. It will take a few coolant flushes to remove all of that.
  5. #5 Re: Lim job
    Sep 2014
    chicago
    Is there any way to clean those intake ports
  6. #6 Re: Lim job
    Without removing the heads and getting them deep cleaned and hot tanked, no not really.
    The biggest issue is just the EGR, it cakes everything.
  7. #7 Re: Lim job
    Sep 2014
    chicago
    Also is there any easy way to clean the injectors without removing them from the rail?
  8. #8 Re: Lim job
    Brake cleaner and a rag wok fine.
    Install new o-rings when you are done.
    Don't worry about breaking the little plastic piece at the bottom of the injector, I bet most of them will be half broke or missing already.
  9. #9 Re: Lim job
    Quote Originally Posted by ayeb View Post
    Uh. no. The holes he circled are the holes for the gasket's locator pins to keep it positioned properly.
    PS.. you need to do more frequent oil changes, that'll clean up that nasty looking lifter valley over time.
  10. #10 Re: Lim job
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I sure hope that's not what my lower intake manifold gasket looks like! My coolant was still fairly clear before it got flushed, just a bit of sludge.
  11. #11 Re: Lim job
    Sep 2014
    chicago
    That's the thing that got me puzzled because my coolant still looks good. Found out my o2 sensor had a dent in it. Prolly from when I got my exhaust work done. I'm just praying I can get this supercharger belt on.
  12. #12 Re: Lim job
    I've seen many gaskets that you would never think were sealing. However the cars weren't burning coolant, it wasn't in the oil pan and everything was overall running well. It's the nature of the plastic frame gaskets. They can start to bow and flex inward at the ports in 20K or less.
  13. #13 Re: Lim job
    Sep 2014
    chicago
    I think kbb should have an option on these motors were if the lim was changed it would raise the value of the car. I don't know if I'm just getting old, because my whole body is sore after that job.
  14. #14 Re: Lim job
    Sep 2014
    chicago
    Ok, problem...... When I go into boost it sputters, sort of like making a pigeon noise with your mouth. I'm thinking it could be the stock belt on a 3.4 pulley. That's the only thing different I did with the lim job
  15. #15 Re: Lim job
    Sep 2014
    chicago
    Cracked spark plug on number 6
