I'm finally making a post about this because it has gotten to the point of driving me a little crazy, and also got me a little worried about something failing.
For as long as I can remember since I got the car I noticed that I could wiggle the steering wheel back and forth in a slight sawing motion and feel a little "thunk" as I did so. I assumed at the time it was either strut mounts, or possibly sway bar bushings and just figured I would let it go until I really needed to change them.
Fast forward and now it seems to have gotten worse. The issue is a little hard to describe, so I might get a little long winded, but please bear with me.
Basically, I can be holding the steering wheel at 12:00, perfectly straight, and when I move the wheel ever so slightly to the left or to the right, there is a thunk that can be felt in the steering wheel. So, lets say 12:00, move right to 12:02, thunk felt at 12:01, back to 12:00, move left to 11:58 thunk felt at 11:59. The thunk only happens right after leaving or returning to 12:00. Sometimes it feels like the steering wheel is harder to move to get out of 12:00, but once moving, moves with ease.
It only makes the thunk when the car is running (obviously with power steering assisting.) Also you can physically feel the thunk in the body of the car. I took it to my uncle's to use his garage to look at it when I did. I had my cousin get in the car and saw the wheel back and forth so he could feel what I was feeling. I was standing next to him with my hand on the open door and could literally feel the door "popping" when the steering was thunking.
I checked the tie rods and front end components and the front end seems "tight."
The possibilities I have run through my head are
-Steering joint on the rack is binding
-Entire rack is going bad
There is another possibility running through my head too. I also have an issue that makes the car feel like the motor mounts are worn, such as sometimes it feels like the engine is moving a lot when I have to get on the throttle sometimes, however I inspected the mounts and they all appear in good shape. Also brake torquing the engine shows no massive movements. This makes me think that possibly I have bolts that have worked themselves just loose enough on the subframe causing both my thunking steering and thunking "engine movement."
With the weather and temps I have not had a chance to get back under it, but I am just looking for some guidance on the issue for when I can finally get another look at it so I can cure it for good.
