Thread: snow performance methanol injection kit
Results 1 to 16 of 16
  1. #1 snow performance methanol injection kit
    Kemmerer, Wyoming
    I've been looking at methanol injection kits made by Snow Performance. they have three kits.
    one that costs 360 stage 1 http://www.snowperformance.net/stage...st-cooler.html
    one that costs 487 stage 2 http://www.snowperformance.net/stage...st-cooler.html
    and stage 3 is 803 http://www.snowperformance.net/stage...st-cooler.html
    for the kit to be as easy to use as possible after being set up, which one is the best choice?
  2. #2 Re: snow performance methanol injection kit
    Dec 2013
    ohio
    I went with basic cooling mist set up. No controller like the stage one kit. It works just fine for me, installed a low fluid light and activation light so I know when it kicks on. Might have got another 30 HP no where as good as NOS set up on my ws6 TA. I would get stage two kit if you were paranoid about blowing up your engine (I am not that concerned myself).
    Djudge1970
  3. #3 Re: snow performance methanol injection kit
    if your kr free with the small pulleys and ic why do meth?
  4. #4 Re: snow performance methanol injection kit
    Kemmerer, Wyoming
    That thought just occurred to me Scott, sometimes I'm slow
  5. #5 Re: snow performance methanol injection kit
    ALLLLLLLLLL of what scott said don't complicate the setup and your not going to gain a thing if your not knocking now it would be pointless.
  6. #6 Re: snow performance methanol injection kit
    Kemmerer, Wyoming
    I will have to get the snout machined and then I will try the 2.6, do you guys think that is too much drop, or should I just go for the 2.55?
  7. #7 Re: snow performance methanol injection kit
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    Devils Own FTW
  8. #8 Re: snow performance methanol injection kit
    Quote Originally Posted by danomite02 View Post
    Devils Own FTW
    this plus even with no KR, depending on where you're timing is at, add more timing LOL.
  9. #9 Re: snow performance methanol injection kit
    Kemmerer, Wyoming
    you can only run so much timing advance
  10. #10 Re: snow performance methanol injection kit
    understandable, thats why it depends on where you're currently at. if only at 16* with the meth and tune, can add a few more degrees
    edit-for example i ran 22-24* with a 3.2"/3.3" and when turbo i ran 20psi with 20* of timing
  11. #11 Re: snow performance methanol injection kit
    May 2008
    Schuyler, NE
    That is too much timing.
  12. #12 Re: snow performance methanol injection kit
    Bastard Reptile's Avatar
    Kansas City, MO
    No it's not. I ran 24* with good results.
    Of course, I bypassed that diluted junk and went with 100% methanol and a DO-10 nozzle.
  13. #13 Re: snow performance methanol injection kit
    May 2008
    Schuyler, NE
    That much timing is hard on head gaskets. You are picking up very little power with that much anyways.
  14. #14 Re: snow performance methanol injection kit
    i think there were debate on how high of timing was considered wasteful. back on CGP someone was able to run as much as 30+ degrees and the motor held up fine but the power was not making anything above 25-26*. i ran 25* on 3.6" to 3.4" on my current motor for a long while and headgaskets are stock and going strong (~200k mikes). reptile, im running 70/30 meth/water on m5 or m6 nozzle.
  15. #15 Re: snow performance methanol injection kit
    Kemmerer, Wyoming
    I'm going to do another pulley drop, trying to decide between 2.6 or 2.55. I can the 2.6 that reptile has for a good price, but I would probably have to get the 2.55 new.
  16. #16 Re: snow performance methanol injection kit
    i think the difference going from a 2.6 to 2.55 is negligible (parasitic loss). at that small a pulley add timing ;-p
  1. methanol injection !
    By 2000supercharged in forum General Tech Discussion
    Last Post: 01-29-2013, 05:31 PM
  2. Water Methanol Injection
    By Speedy1973 in forum General Grand Prix Discussion
    Last Post: 07-26-2012, 09:10 PM
  3. Methanol Injection ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-01-2010, 08:28 PM
