Thread: Ford Probe Heater Core??
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Ford Probe Heater Core??
    Jan 2015
    Syracuse, NY
    The rubber isn't all it's cracked up to be. I tested this out when it was being looked at etc.
    what did you use it on phenolic or aluminum? What problems did you run into. did you use the same thickness?
  2. #22 Re: Ford Probe Heater Core??
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I just found it weird that the 1-5/8 core is the right one, but I guess it is.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #23 Re: Ford Probe Heater Core??
    Quote Originally Posted by BOOGIEMAN View Post
    Aluminum. Same core pictured in the last post of the previous page. It gets dirty etc and doesn't seal as good as good old paper and rtv. It's easy to tighten bolts and have it bunch etc. I like to torque the SC down to it's ~17ft lbs
  4. #24 Re: Ford Probe Heater Core??
    Buffalo
    http://pages.ebay.com/link/?nav=item...d=371126788448
    should work then for a gen5 zzp FSIC ?
  5. #25 Re: Ford Probe Heater Core??
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by crazyguy03 View Post
    Should be the same core for both. only difference is the opening of the ic is bigger on gen v.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #26 Re: Ford Probe Heater Core??
    Buffalo
    Thanks. Better to ask then guess
  1. heater core
    By dlk in forum General Grand Prix Discussion
    Last Post: 04-22-2014, 06:29 PM
  2. Heater core
    By jase711 in forum General Tech Discussion
    Last Post: 02-18-2013, 01:29 PM
  3. (Wi) For trade: Ford Probe GT
    By Josh Ehlert in forum For Sale - Vehicles
    Last Post: 06-05-2012, 11:44 PM
  4. Ford probe GT stalling out after a couple miles
    By tcman49 in forum General Tech Discussion
    Last Post: 10-03-2011, 07:49 AM
  5. Ford Probe
    By Lsick7 in forum Track Sessions and Kills
    Last Post: 08-23-2011, 10:20 AM
