Thread: Front end issues
Results 1 to 10 of 10
  1. #1 Front end issues
    Oct 2014
    North carolina
    I have a 02 2 door gt with 90k miles all michigan driving until recently. I have tried to look up my issues before posting but im not coming to my answers anywhere. I have a bad front end viberations tires are good and balanced. I also am getting a loud clunk when i turn hard and now ive also noticed my front drivers side tire is almost slick on the inside like its got a bad castor. I have notice the back drives toes out at the bottom way more than any other tire but that rubber seems fine. Not sure what to start looking into im a cherokee (straight axle) guy so have almost no idea about what to loom for with IFS any and all help will be great i can fix it and find out if its bad if i know what to look for. I just feel like im chasing my tail right now
  2. #2 Re: Front end issues
    Loose tie rod ends or lower ball joints will cause tire wear on the inside edge.
    I would shake down the front end and see if there is any movment at 9 and 3 on the tire.
  3. #3 Re: Front end issues
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    I kinda have a issues like this.But with 98 GTP,
    When shaking the tire 9 and 3, do i need to jack car first?
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  4. #4 Re: Front end issues
    Yes, you want to raise the front tires off the ground. Just jack it up in the middle of the subframe that runs across the front, both wheels will come off the ground, keep the key in the ignition so the steering wheel doesnt lock.
  5. #5 Re: Front end issues
    Oct 2014
    North carolina
    Ill check those couple things outs if it helps my viberation is at 45 mph also at under 25 it almost feels like i have a flat tire like a whomp whomp whomp whomp feeling like my tires flat or loose which is neither issue
  6. #6 Re: Front end issues
    Jul 2014
    New Jersey
    i had something similar, not quite as bad, but mine was just a bad outer tie rod
  7. #7 Re: Front end issues
    lca's were my clunk over bumps, bad ball joints, strut mounts can also clunk.
    in the end replacing all the front end parts is not a long list,
    lac's, 100 for the pair or less bought on line.
    tie rods ends 40 to 60 depending on brand.
    strut mounts are like 30 a side iirc. i took my struts out, dropped them off at a front end shop to swap the mounts, if you dont have air tools, your not changing them at home. ( they charged me like 30 bucks to swap em)
    if you change the lca's buy new sway bar end links 99% of the time the bolt snaps, or strips and you cut it off. they run like 10 bucks for the pair.
    once all this or any of these parts are changed you'll need to hit the alignment show asap. that should fix the back end up.
    and if you can get a new set of tires on the car its best to get it aligned with good tires. even if you borrow a set from another car, aka temp tire and wheel swap.
  8. #8 Re: Front end issues
    Oct 2014
    North carolina
    Dang thanks for all the fast replys. When i was a cherokee noob i asked a question on a forum and got my a hole chewed for not researching enough i appreciate all the advice!
  9. #9 Re: Front end issues
    we are used to your kind lol we wont beat you up till you get real stupid sounding.
    if your to dumb here we just ban you it seems lol but the dumbness needs to be proven time and time again before that happens.
    carry on, welcome to club.
  10. #10 Re: Front end issues
    GT Level Member Shiftingshaddow's Avatar
    KC
    could be possible there are several different issues. when i read your vibration issues at 45 mph and the clunk when you turn hard i thought it could be a bad cv joint. that wouldn't account for the tire wear so that could be bad alignment, bad control arms, bad hub, bad tie rods (could be the clunk as well), even the steering rack can clunk if its bad. all those things can cause bad alignment or the car not being able to hold an alignment which will eat the tires up.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  1. Help 05 gxp front steering noise/issues
    By LSFoFaSho in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2014, 09:06 PM
  2. Anyone have the same front tire issues?
    By PonchoMuscle in forum Tires & Wheels
    Last Post: 08-11-2011, 12:48 AM
  3. front end issues.......
    By twol8uluz in forum General Tech Discussion
    Last Post: 05-01-2011, 09:07 AM
  4. New Front O2 leads to issues...
    By Mr Chill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2010, 10:40 AM
  5. Front suspension/steering issues
    By 07CrimsonGT in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 08:52 AM
