Thread: Supercharger parts
Results 1 to 19 of 19
  1. #1 Supercharger parts
    SE Level Member 1BadGT's Avatar
    Oct 2014
    Dalton,OH
    Anybody got an opinion on a supercharger from a junkyard. Found one from a GTP here at a local junkyard for $150. The GTP had 72,xxx miles, any thoughts and opinions, I'd like to pick one up for cheap to top swap mine but didn't know if I should pull the trigger on this?
    Sent from 1BadGT's Rooted Galaxy S5!
  2. #2 Re: Supercharger parts
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    Look around on here to see if you can find a lower price.. However 150 isn't a bad one. You should however look into what is involved four a top swap. These are most of the things that you'll need to change in order for the SC to work... The heads, LIM, coil pack bracket, harmonic balancer, MAP sensor, MAF sensor, fuel rail, fuel line fittings, you'll need a tune, and I strongly recommend you add headers to the list. As for whether you should buy it, take the belt off and make sure it spins freely. Then unbolt it from the LIM and check to see if the Teflon coating is coming off. If it is then don't, but I believe. Small amount of peeling is ok... Just undesirable.. I may have missed some things in the part list so look into it more
  3. #3 Re: Supercharger parts
  4. #4 Re: Supercharger parts
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by 1BadGT View Post
    Most parts from a junkyard have a 30 day warranty
    PM me if you want to know more about top swapping, I recently helped assemble one.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  5. #5 Re: Supercharger parts
    Banned
    Jan 2013
    maryland
    Funny they are charging that price .. at the pick and pull I paid 55 bucks for the Gen v and 15 for the manifold so I venture for the topswap setup it would be 150 for everything just keep looking OP
    Sent from my T-Mobile myTouch Q using Tapatalk 2
  6. #6 Re: Supercharger parts
    Oct 2014
    Dalton,OH
    Thanks everybody, I'm searching everywhere and holding out till I find the very best price I can find. The 150 was the lowest I've found so far but I'll keep watching. I've read those threads and have wrote everything down that I need as well. I'll ask for help if I require it.
  7. #7 Re: Supercharger parts
    Jun 2012
    Minot, Nd
    i got the whole top end for my project for 100 bucks at the JY hehe
  8. #8 Re: Supercharger parts
    Oct 2014
    Dalton,OH
    Nice man. There's a pull a part here in Akron, Canton, and Cleveland and it's cheaper than most junkyards. I've been checking them out.
  9. #9 Re: Supercharger parts
    Jun 2012
    Minot, Nd
    yeah just have to keep searching. good luck with your search!
  10. #10 Re: Supercharger parts
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by jayroca View Post
    Funny you should mention that, my local yard doesn't list a price for superchargers period... so it's up to the sales person at the desk to determine a price. I had my eye on an M90, so every day, I would ask the sales person for a price. Eventually, I had a nice lady give me a price of $20. You can guess what happened next.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  11. #11 Re: Supercharger parts
    Oct 2014
    Dalton,OH
    Would it be better to get an M90 from an 04+ GP? Mine is an 02, I know there was a difference in the engines s little bit but would a newer one do just as good as a 97-03 S/C?
  12. #12 Re: Supercharger parts
    Mercer, Pa
    04 or newer GP has a gen 5. Yes it is better but must get an adapter for throttle body. Not a hard swap but not a direct swap.
  13. #13 Re: Supercharger parts
    Apr 2013
    White Lake
    You could always wait until black friday on ZZP site. Last year they had a topswap deal if I can remember it was just under a $1000 for the first one to order it. Which it comes with EVERYTHING you need to topswap.
  14. #14 Re: Supercharger parts
    Oct 2014
    Dalton,OH
    Quote Originally Posted by CyxRyan View Post
    Good ****, never thought about that! And black Friday is approaching quickly as well! -Touche'
  15. #15 Re: Supercharger parts
    Apr 2013
    White Lake
    YEP! Pretty sure first buy was 50% off and it was up for about 30 min after zzp posted on fb before someone got it. If only they offered it for 2004+ :"(.
  16. #16 Re: Supercharger parts
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    if you spend 1000 on a topswap you spent way tooo much
    04 GTP -HAI, 1.9 rockers.
  17. #17 Re: Supercharger parts
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by SnowTh1ef View Post
    This.
  18. #18 Re: Supercharger parts
    Apr 2013
    White Lake
    Well... i'd say it was between 800-900ish so just under a 1000 ^_^. If I could find a whole top swap for under $1,000 i'd buy it in a heart beat for my 05 GP!.
  19. #19 Re: Supercharger parts
    Aug 2013
    Sandy, UT
    buy my ssm90 lim and fuel logs and pulley setup, grab a gen v and youre done for under 800 i bet.
  1. Supercharger rebuild parts
    By Silver GTP in forum General Tech Discussion
    Last Post: 04-29-2010, 06:19 PM
