Thread: I need help code p0102
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 I need help code p0102
    SE Level Member LHRxXD3adXx's Avatar
    Oct 2014
    Hey guys lately ive been fighting with my car to get it back up and running. I did a full rebuild to the engine and ever since i put it back it has been giving me this code p0102. I replaced my mass air flow sensor which was $220 and hoped that was it but nope it wasn't were else should i look?
  2. #2 Re: I need help code p0102
    The wire harness going to it and likely damaged or faulty.
  3. #3 Re: I need help code p0102
    check the fuse box for a blown fuse, 24 or something like that. also bad wires to the maf can cause the low Circuit code
  4. #4 Re: I need help code p0102
    Oct 2014
    Ok ill do that tomorrow morning thanks
  5. #5 Re: I need help code p0102
    Oct 2014
    How could it be damaged? Like a bad connection or something?
  6. #6 Re: I need help code p0102
    thos wires bake in the heat of the crossover pipe, insulation can fall off or have cracks. <<<this will cause a code.
  7. #7 Re: I need help code p0102
    Oct 2014
    I know what its is then ive got headers and they produce a lot of heat so that must be it
  8. #8 Re: I need help code p0102
    mine were shot to hell stock. wires had dry wire 2 inches from the main harness. both my maf and ait sensors pig tails were toast.
  9. #9 Re: I need help code p0102
    Oct 2014
    Hey its my fuse but it keeps going out. Where should i look
  10. #10 Re: I need help code p0102
    Oct 2014
    I got it to work once and then it went out. Now as soon as i turn the key on it goes out
  11. #11 Re: I need help code p0102
    check the o2 sensor wires and the maf wires.
    or if you have a open cone filter and the pcm laying on the frame, look for a rubbed wire to the pcm.
  12. #12 Re: I need help code p0102
    Oct 2014
    Ok i will when i first changed it it was fine and i went for a drive for the first time since ive had it in the garage so that was like over a year ago and it ran like hell hit about 55 on 1st gear then 100 on second and now everytime i turn the key on it blows the fuse. This is the last thing i need to figure out so i can finally bring it out agian! Im so excited ha. Ive checked the maf wires they are fine idk about the o2 ones.
  13. #13 Re: I need help code p0102
    Oct 2014
    How come i ran fine the first time tho?
    And i do have the cone filter and pcm on the frame
  14. #14 Re: I need help code p0102
    when the fuse keeps blowing its mostly due to a bad wire somewhere.
  15. #15 Re: I need help code p0102
    Oct 2014
    Ok then i hate these ones haha just because sometimes it takes for ever to find it but at least i know what it is. Before i was all over the place trying other things but now i now what it is
  16. #16 Re: I need help code p0102
    Oct 2014
    Found it!! So some idiot before me did this!
    It was hitting the headers
  17. #17 Re: I need help code p0102
    Dec 2012
    Where 4T65E's were born
    Man that makes me cringe. Solder and heatshrink is my preferred method.
    Sold.
  18. #18 Re: I need help code p0102
    nice lol.
    you want to cut them apart, strip the wires back on both sides till you get clean shinny copper, then solder and shrink tube them back together.
  19. #19 Re: I need help code p0102
    Oct 2014
    Yup doing it in a bit. Man my car has been sitting the last 3 month because of this crap. I did everything you could possibly think of until i joined this forum and you guys help me track it down to this. Thanks to everyone that helped.
  20. #20 Re: I need help code p0102
    should have came here sooner. we see stuff like this a lot. pretty common if the fuse keeps blowing.
  1. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  2. MAF P0102 Code
    By gp99 in forum Introductions/Noob Questions
    Last Post: 08-27-2013, 01:08 PM
  3. p0102 code help
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2012, 06:47 PM
  4. odd p0102 code
    By myzerman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2009, 05:18 PM
  5. code p0102
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:09 PM
