Thread: 99 cobra wheels
Results 1 to 20 of 23
  1. #1 99 cobra wheels
    GT Level Member Jonarin's Avatar
    Oct 2014
    These wheels have a 5x114.3 bolt pattern, 16x8, 129mm back spacing. Would they fit on a 97 grand prix
  2. #2 Re: 99 cobra wheels
    hangover park IL
    they will but the car wont run right and will start breaking down more often from the ford stigma
    ~James~ Psychotic Gearhead
  3. #3 Re: 99 cobra wheels
    Oct 2014
    Hmmmmmm
  4. #4 Re: 99 cobra wheels
    hangover park IL
    yeah, ford cooties are bad
  5. #5 Re: 99 cobra wheels
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Generally, it's considered a bad idea to put 114.3 bolt pattern wheels on a hub with 115 pattern. A lot of rednecks do it anyway and say they have no problems... but why take chances on friggin wheels?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: 99 cobra wheels
    It'll be fine...
    Do you know how many of us run the 5x114.3 bolt patterns without any issues? Nothing redneck about it it just gives you a greater selections of wheels to choose from. They make hub centric rings for a reason and just torque your lugnuts like your suppose to go and have no worries about braking a stud.
    04 Comp G.
  7. #7 Re: 99 cobra wheels
    Quote Originally Posted by GTP131 View Post
    you are high .7 is not going to matter at all zero none not at all......
    pretty much every style of oem mustang wheels have been put on these cars they WILL fit.
  8. #8 Re: 99 cobra wheels
    just proceeding to add to this...
    the general tolerances for the bolt patterns on wheels probably makes up for this difference already.
    as well as most bolt patterns are designed to be semi-universal. 114.3/115, 120/120.65....it's a simple metric to standard conversion...
    i WILL be running 5x120 wheels on my 5x4.5 (120.65) hubs and not caring because it's just that close that it doesn't matter.
  9. #9 Re: 99 cobra wheels
    Knoxville, TN
    Wow, no idea I would pinch a nerve on this subject.
    Like I said, I haven't heard of any problems of doing so... but I wouldn't tell another person that it is alright to use the incorrect pattern.
    It is probably also worth mentioning, if you have another company such as Discount Tire rotate and balance your tires, it is possible they will refuse to touch your wheels for this reason. I doubt the company that manufactures the wheels will tell you this is OK, either.
    Sure, these policies may be from just liability concerns. Still, I wouldn't recommend using the wrong pattern to someone I don't know.
  10. #10 Re: 99 cobra wheels
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    .......... You really think discount tire is going to measure, or much less even notice the .7 mm difference in the bolt battern? No they won't.
    And everyone who upgrades to FBody brakes, those brakes bolt patter in the disc is much different that the Gp bolt pattern. Also those who do the GXP brake upgrade and run mustang gt500 rotors. Same store.
    04 GTP -HAI, 1.9 rockers.
  11. #11 Re: 99 cobra wheels
    For the record, I ran 114.3 bolt pattern wheels FOR YEARS.
    **** the difference.
    It don't matter.
  12. #12 Re: 99 cobra wheels
    May 2008
    Schuyler, NE
    My slicks and skinnies are 114.3. Haven't broke a stud yet.
  13. #13 Re: 99 cobra wheels
    GTP Level Member buickman104's Avatar
    NYC
    As long as the hub bore is the same or you have hub centric rings to eat up the difference there is no problem.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  14. #14 Re: 99 cobra wheels
    6 years or so running 2 different sets never had a problem and never had a problem getting my tires rotated at big shops..
    04 Comp G.
  15. #15 Re: 99 cobra wheels
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    The nerve you pinched is in making the statement "a lot of rednecks do it" when I would guess the majority of people on this forum with aftermarket rims are using 114.3. So you just called all the aforementioned people rednecks.
  16. #16 Re: 99 cobra wheels
    as well as spreading misinformation.
    like saying powder coating wheels does anything to change the properties of the metal.
  17. #17 Re: 99 cobra wheels
    Aug 2013
    Sandy, UT
    .... Where was this said? Lol
  18. #18 Re: 99 cobra wheels
    lots of people think that's the case. it's not part of this thread, however.
  19. #19 Re: 99 cobra wheels
    Mar 2012
    NC
    Anodizing does though... *hide*
  20. #20 Re: 99 cobra wheels
    Knoxville, TN
    I'm willing to take your words for it if you haven't run into issues with an alternate bolt pattern. I retract the "redneck" label. Not fair to lump you guys into the same category as people who use standard compression fittings on brake lines and crap like that. That said, it still doesn't seem like a good idea to give people advice to use something that could possibly (even remotely) be unsafe as far as any suspension component goes.
    I've seen a fair amount of debate on other performance websites over whether or not it is safe. Also seen a lot of debate over using hub-centric rings on wheels that aren't using the factory lug pattern as well. I see no reason to believe that this subject isn't at least debatable. As far as casting tolerances... what if the holes for the lugs are on the small side of the tolerance? Food for thought.
    Glad that the big tire shops haven't bothered anyone on here about their alternate-pattern wheels. I've read stories from others about purchasing 114.3 pattern wheels at one shop, and having other shops turn them away for servicing. I'm not suggesting that the tire shops actually measure the wheels, but wouldn't some wheels have the bolt pattern printed/cast into them somewhere?
  1. Cobra R Wheels look BAD ASS!!!
    By japslpr in forum Tires & Wheels
    Last Post: 05-28-2014, 09:02 AM
  2. 99-01 Cobra Wheels and tires
    By redgtp97 in forum For Sale - Parts
    Last Post: 12-01-2013, 11:34 PM
  3. Cobra R wheels on GP?
    By 97PAGTP in forum Tires & Wheels
    Last Post: 07-28-2011, 11:42 PM
  4. will 95 mustang cobra wheels fit 98 gtp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 11-04-2009, 11:30 AM
  5. Cobra wheels on a GP?
    By pski920 in forum Tires & Wheels
    Last Post: 11-09-2008, 07:57 PM
