Thread: oil leak
Results 1 to 20 of 38
  1. #1 oil leak
    Sep 2014
    montreal
    hello,
    i have just bought my very first car. being short of money (and knowing that winter will come soon here in montreal), i decided to cheap out and instead of getting e more recent car on financing i decided to buy a grand prix.
    mine is a 2004, in red, GT trim. it has a whopping 360,000km on it (about 220k miles, i think), but it looks alright. only a tiny bit of rust, and the only things that don't work are the AC (useless in winter anyway) and the radio LCD.
    i paid a lousy 700 bucks.
    however, it has now started to leak oil, a mere two days after i bought it. i cannot really tell where the oil is coming from, except "from the middle somewhere"... which really rather sucks.
    i pulled out the dipstick, and it shows the oil level in between the two holes in the stick, is that enough?
    i took the oil cap off after a 2 minute drive, and steam slowly rose... is that normal? the gauge shows temps are in the middle, but can i really trust that gauge?
    i am not going to spend a ton of money fixing a car i won't keep longer than 6 months anyway, so any help or ideas on how to fix this on the cheap is greatly appreciated.
  2. #2 Re: oil leak
    How much is it leaking? Like a big puddle?
  3. #3 Re: oil leak
    Sep 2014
    montreal
    i'd say a can of coke has leaked in maybe 30 minutes
  4. #4 Re: oil leak
    Sep 2014
    montreal
    the really bad part is that i actually like the rest of the car... i mean, i bought it a s a winter beater, but my 6'4" frame fits it perfectly and i like the design now... damnit lol
  5. #5 Re: oil leak
    on the pass side more? probably the oil pressure sensor. its like 12 bucks to replace.
    car running, turn the wheels all the way left, them look from the back of the front tire, find the oil filter, then look to its left for a sensor with a green plug, thats the oil pressure sensor, if its leaking oil will be dripping from the green plug.
  6. #6 Re: oil leak
    Just sitting there not running? Are you sure it's oil?
  7. #7 Re: oil leak
    Sep 2014
    montreal
    so i jut went outside to take a picture, and the leak appears to actually have stopped. very strange. i will report back later to see if it happens again, or if maybe there simply was a bit too much oil in there somewhere?
  8. #8 Re: oil leak
    im 6'6" and fit just fine in my regal. i do have the drivers seat laid out like a lazy boy recliner tho lol
  9. #9 Re: oil leak
    Sep 2014
    montreal
    thanks for teh advice; and well, it is a fluid the color and consistency of cooking oil, so i think the old owner maybe put too much in... or could be it from the power steering?
  10. #10 Re: oil leak
    Quote Originally Posted by montrealwest View Post
    oil pressure sensor olny leaks when the car is running pretty much, check that thing out.
    and oil on the dip stick should be @ the full line. or a dot or 2 lower is ok.
  11. #11 Re: oil leak
    Sep 2014
    montreal
    i took some pics outside just now. the oil level is in fact at five dots (dunno why i said two before).
    the leak seems to coming from the left side of the engine, but has stopped now.
    oil leak Attached Images
  12. #12 Re: oil leak
    Sep 2014
    montreal
    here's a better shot, the forum says i cannot post it because i have exceeded my quota...
    http://postimg.org/image/vzkzff6s1/
  13. #13 Re: oil leak
    looks like the front valve cover is leaking. in this pic there if you look to the right under the coils its real wet looking there.
    take a rag or paper towle, wipe under the valve cover bottom lip, see if its wet with oil.
  14. #14 Re: oil leak
    Yeah likely valve covers leaking. I'd do both of them.
  15. #15 Re: oil leak
    Sep 2014
    montreal
    http://postimg.org/image/5biglh91n/
    http://postimg.org/image/x4jzj03d5/
    there does seem to be oil, it isn't wet anymore, but there seems to be quite a bit, maybe accumulated over time.
  16. #16 Re: oil leak
    Sep 2014
    montreal
    and how much is it to fix that, if it is the valve covers?
  17. #17 Re: oil leak
    to do yourself, recommended way to go here, 60 to 75 for the new gaskets and grommets. thats for a felpro set. dont think id try another brand.
    at a shop could be 200 or more, depending on the shop.
  18. #18 Re: oil leak
    Sep 2014
    montreal
    well that's not too bad... thanks for your help! in the meantime, i assume i can drive the car, as long as i top up the oil?
  19. #19 Re: oil leak
    Be careful because oil is flammable and it's leaking onto the front manifold which is very hot.
  20. #20 Re: oil leak
    truth is that can catch fire and bye bye new used car.
    so fix it asap.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
