Thread: Airbag MIL
Results 1 to 7 of 7
  1. #1 Airbag MIL
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Anybody know why the airbag indication would come on the dash and stay on? its done this plenty of times in the past and usually stays on for a good minute(like weeks) when it does than it'll go off. Currently its been on for like 3days and I just don't know why it does this. Maybe a wire is loose or shortened, but im just confused on how it comes and goes. LOL, last similar issue I had like this was the coolant MIL and I just unplugged that for good bc I just got tired of it. LOL, I cant unplugged the airbag bc that's just one thing I may need one day.
    Any help would be great....
    00' regal GS
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: Airbag MIL
    could be the airbag module under the pass seat, they tend to corrode up and fail to ground.
  3. #3 Re: Airbag MIL
    Dee..
    With the ignition off, move the button on the side of your driverside seat so that the rear of the seat bottom lifts up all the way.
    Open driverside rear door
    Kneel down and locate the yellow connector under the driverseat
    Remove the blue safety pin that ensures the connector can not come apart accidentally
    Disconnect that yellow connector
    Connect that yellow connector
    Repeat 4 more times for 5 disconnects and 5 connects
    Put blue thing back in place
    Stand up
    Close passenger rear door
    Fix your drivers seat back to it's normal position
    Repeat this procedure once a summer, because for some reason...it only seems to happen once a summer if you follow the above.
    Yup.. just fixed mine this morning!
  4. #4 Re: Airbag MIL
    PS..
    00+ have an airbag on the side of the drivers seat
  5. #5 Re: Airbag MIL
    Jul 2012
    North Philly
    Dee..
    Stand up
    WoW, just read this....been away for a lil bit, I'll do this A.S.A.P
  6. #6 Re: Airbag MIL
    Jul 2012
    North Philly
    Yeah Bill, meant to tell you that the air bag connector trick worked perfectly.
  7. #7 Re: Airbag MIL
    Yeah Dee... I kinda knew it would (work for me).
    Glad it worked for you too.
    Next year, you'll know exactly what to do. hahahahaha I honestly get this happening once a year and always mid summer.
  1. Airbag light
    By Rsmolarek in forum General Tech Discussion
    Last Post: 03-13-2013, 02:38 PM
  2. Airbag Light
    By djwags in forum General Tech Discussion
    Last Post: 04-10-2012, 05:50 PM
  3. SRS airbag light on
    By Mnasrv in forum General Tech Discussion
    Last Post: 12-29-2011, 09:11 PM
  4. srs airbag
    By pacothetaco in forum General Tech Discussion
    Last Post: 08-02-2009, 11:13 PM
  5. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
