So yeah, my LS starts and immediately shuts back off. it then starts right back up after turning the key back on and pretty much runs flawlessly for the rest of the day. its very intermittent so it shuts off randomly and we'll never know when its going to shut off again. It does this with a cold or hot engine. I've checked all sensors, cleaned all valves, and the air intake. Im getting no codes for this problem, ive also checked all vacuum lines. Battery is fine pretty much new and is still putting out correct battery voltage and alternating voltage. Fuel PSI is within specs, coils are firing strong, oil/filter has just been changed and all ignition components are new.
Weird thing is that on first startup it fails but after the 2nd attempt it runs perfect on the highway and in general. again theres no codes and nothing seems out of the ordinary. Only thing I can think of is the Crank sensor, Cam sensor, ignition switch, or Oil PSI...and I don't even think these are the issues bc again the car runs great after starting. with my opinions if these were the causes than I would think the car would run like **** and that's if it would start and stay running with the possible issues ive stated.
Im pretty loss, any ideas?
