Dee..
With the ignition off, move the button on the side of your driverside seat so that the rear of the seat bottom lifts up all the way.
Open driverside rear door
Kneel down and locate the yellow connector under the driverseat
Remove the blue safety pin that ensures the connector can not come apart accidentally
Disconnect that yellow connector
Connect that yellow connector
Repeat 4 more times for 5 disconnects and 5 connects
Put blue thing back in place
Stand up
Close passenger rear door
Fix your drivers seat back to it's normal position
Repeat this procedure once a summer, because for some reason...it only seems to happen once a summer if you follow the above.
Yup.. just fixed mine this morning!
