Thread: Replaced crank position sensor now car runs horrible
Results 1 to 13 of 13
  1. #1 Replaced crank position sensor now car runs horrible
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    We'll today I replaced the crank position sensor then after I started putting things back together I tried starting it and it's idling rough. I'm gonna check and make sure I put the harmonic balancer in right and try again but if it still does it I'm stumped. I know you gotta do a case learn afterwards but would that really be that much of a difference?
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  2. #2 Re: Replaced crank position sensor now car runs horrible
    Ok I checked the how to section again and noticed I forgot to push down and turn the harmonic balancer til it locks in. I pulled the harmonic balancer out again and put it back, I've been pushin and turnin and it still won't lock in.
  3. #3 Re: Replaced crank position sensor now car runs horrible
    We'll it gets even better now, after I put the balancer on again, I went to start the car and now it won't start. It will crank but won't start.
  4. #4 Re: Replaced crank position sensor now car runs horrible
    So the key way is lined up and HB got pushed in all the way??
    I used a impact to make sure it was, that way the metal fins inside the HB went across the crank sensor to send the signal.
  5. #5 Re: Replaced crank position sensor now car runs horrible
    I used an impact wrench to tighten it down. To be honest I wasn't able to get it to lock in, I pushed and turned on it for a half hour and I was still able to turn it, however if I pushed down and turned at the same time i couldn't turn it, but if I just tried to turn it I could turn it all day. I just gave up last night to clear my head and I'm gonna get back at it today.
  6. #6 Re: Replaced crank position sensor now car runs horrible
    HUDSON
    Pull the HB back off and make sure the key way has not sheared off.
  7. #7 Re: Replaced crank position sensor now car runs horrible
    Pulled the balancer off, is the keyway a separate piece or is it part of the shaft? I see the hole on the shaft that matches the one on the balancer but I don't see anything to lock them in with. Am I screwed? Thanks for the replies btw, I've been rackin what's left of my brains out over this thing and really appreciate the help
  8. #8 Re: Replaced crank position sensor now car runs horrible
    Ok bought a new balancer with new keyway. It's a dorman, I put the new keyway in on crank side and now I can't slide the new balancer on enough to be able to thread the bolt to tighten it down the rest of the way. I can get the balancer lined up to the keyway but it only goes but so far in. It's almost like the new keyway isn't the right size
  9. #9 Re: Replaced crank position sensor now car runs horrible
    Can't just slide it in.. you have to pull the timing cover and make sure you didn't have the crank spin while the cam stayed put. Pull the cover off...get tons of pics of the crank gear/crank and keyway area.. post them and we should be able to tell you how good/bad things are.
  10. #10 Re: Replaced crank position sensor now car runs horrible
    The idea with this post was for us to see it as well and guide you in the best way possible. It's possible the engine is crap because of a bad crank (if the key screwed it up) It's also possible that the key came out and the crank spun w/o the cam spinning. All these are bad.
  11. #11 Re: Replaced crank position sensor now car runs horrible
    Feb 2009
    flintnasty MI
    If you ever wanted to swap in a cam now might be a good time.
  12. #12 Re: Replaced crank position sensor now car runs horrible
    Ok cool thanks, I'm gonna try to tear into it tonight. What should I be looking for and what's the worst case scenario am I looking at here?
  13. #13 Re: Replaced crank position sensor now car runs horrible
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    You might be pushing the key into the crank and out of its slot when you push the pulley in. look at the key it should have rounded edges on one side. turn the crank so the key way is straight up in eng. put key in slot with round part up and a little protruding start pulley on shaft it should go in far enuff to start the bolt and pull in.
  1. Crank position sensor
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2014, 08:54 PM
  2. Crank position sensor?
    By chris99gtp in forum General Tech Discussion
    Last Post: 12-17-2013, 09:51 PM
  3. New guy from SD, Crank position sensor help.
    By Mak90 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-15-2012, 09:14 AM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
