I have an '02 gtp. Just recently I have been having issues with my wipers. I'll set the speed on the lowest intermittent setting and they will run fine, and then randomly run constantly. If I switch the speed to any other speed, except for the high constant, they continue on the low continuous speed. Eventually they switch back to intermittent again. If I go into high constant, they run just fine, no issue. I've had the issue where when I turn off the wipers completely when this is happening, they will wipe an extra 2-5 times before they shut off.
Would this be cause for a new wiper switch? It looks like those might run a few hundred and if that is the case I might just put up with it, but I thought I'd ask if anyone has other ideas?
