Thread: 2007 gxp
Results 1 to 18 of 18
  1. #1 2007 gxp
    Nov 2012
    Illinois
    As some of you may know I've been looking into fixing up our 2005 GT Unfortunately my wife was involved in a car accident last week and the car is being totaled. So now we are in the market for a new car. We've found a 2007 GXP online (haven't seen it yet) and have a couple of questions:
    1. How does the GXP compare to the GT. I know the GXP is a V8 but what else is different about it? Does it handle differently? How does the gas mileage compare? How will it handle in the winter?
    2. Are there any issues about the GXP or the 2007s I should be aware of?
    3. When we go to look at it, what things should I be looking for?
    Thanks in advance.
  2. #2 Re: 2007 gxp
    Aug 2013
    McDonald PA
    Issues with gxp. Is the dod the afm. The trans temp. It burns oil but that's an ls thing lol gas is gonna be a little lower. 91parkave needs to chime in
  3. #3 Re: 2007 gxp
    new britain, ct
    like you said, obviously the v8. however it has a way better suspension set up from the factory, top of the line struts, bigger sway bar, and lower by an inch. the tires are staggered sizes. the fronts are 255's and the rears are 225's. bigger brakes and drilled rotors from the factory.
    depending on where you are from, look for rust. i know its a 2007, but still. the main issue with these cars is the transmission. when you drive it, make sure it is shifting smoothly and see if you can get it up to operating temperature. make sure the driver information center works (not an issue normally), but it has a temperature gauge for the transmission on it and it shows how hot its getting. make sure the torque converter isnt slipping when going into overdrive at about 45 mph.
    good luck and sorry about your wifes accident. glad shes ok.
    07 Black GXP.
  4. #4 Re: 2007 gxp
    Oct 2011
    Puyallup WA
    Comp g or gxp
    08 G8 GT - exhaust Tune
  5. #5 Re: 2007 gxp
    Nov 2012
    Illinois
    Thanks for all the great info! I believe it is a gxp (it says gxp on the dealer website and says it has a V8). To be honest, I'm not sure what the difference between the two is.
    Does a gxp need premium gas?
    What is "dod the afm"?
  6. #6 Re: 2007 gxp
    new britain, ct
    GXP or comp g, or any supercharged car all need premium gas. (supercharged would be GTP, or comp G, or 2006+ GT)
    "dod" stands for displacement on demand. the car will shut off 4 cylinders while cruising to save fuel.
    "afm" is essentially the same thing- it stands for active fuel management.
    do you do a lot of city driving? there can be problems with the torque converter because it would be switching from 4 cyl to 8 cyl a lot and that can wear down on the torque converter.
    other things the GXP has standard. it has electric heated leather seats with suede inserts and i think all come with an upgraded sound system called the monsoon system.
    07 Black GXP.
  7. #7 Re: 2007 gxp
    Nov 2012
    Illinois
    It is definitely a GXP (I checked on the website.....says it on the dashboard display in the picture).
    Thanks! We live in a far west suburb of Chicago so I'd say we do a mix of highway and city driving. From the CarFax report, it looks like a rental company owned it for the first 13k miles/5 months and then a private party owned it the remainder of the time. It only has 76k miles on it so it's low miles (about 10k a year).
    Is the transmission the same that was in out 2005 GT? About $2k for a new transmission if it were to go out, correct? How much to repair torque converter.
    How expensive is it to have displacement on demand and active fuel management issues fixed? Is there any way to tell if there are issues with either of these when we test drive?
    Overall we had very good luck with our 2005 GT (it had about 130k miles on it). Would you say the GXP is not as reliable as the GT?
  8. #8 Re: 2007 gxp
    Aug 2011
    'Merica
    I would do a trans fluid replacement, add a shift kit, a bottle of Lucas and a trans cooler. To help the trans.
  9. #9 Re: 2007 gxp
    Aug 2011
    'Merica
    You can also have dod tuned out IIRC
  10. #10 Re: 2007 gxp
    Aug 2013
    McDonald PA
    Quote Originally Posted by Below Average Joe View Post
    Big tranny cooler and a shift kit the trans go one
  11. #11 Re: 2007 gxp
    new britain, ct
    it all depends on how you drive it too.
    its got the same trans except this one is "heavy duty" and it has tapshift. the thing that kills them is the heat. buy a transmission cooler and it should last a while.
    you can get a tune to get your dod tuned out, itll keep it in 8 cylinder mode all the time, and i hear that a tune will help you extend the life of your transmission.
    overall, i would say there is more of a chance for the transmission going out on the GXP than the other models. some are really lucky some arent, but that goes along with any car on any platform what so ever.
    if its JUST reliability you want, maybe go for another GT or a GTP. i think those models are more reliable.
    from personal experience, i took a chance and bought a GXP and i still love it. 6 months and no problems.
    07 Black GXP.
  12. #12 Re: 2007 gxp
    Aug 2013
    McDonald PA
    ^^^ ahhh nope same trans. Not heavy duty
  13. #13 Re: 2007 gxp
    Aug 2011
    'Merica
    I bought an 05 GT and within a few months I had to replace the trans. Bought one from TEP and a cooler to go along with it. We don't beat on it as its my wife's dd/kid hauler. Trans temp would hit 221 and start to slip and hard shift.
  14. #14 Re: 2007 gxp
    Nov 2012
    Illinois
    Thanks! How much is the transmission cooler, a shift kit and a dod tune? Are these things I can do myself? How will these affect performance and gas mileage?
  15. #15 Re: 2007 gxp
    Aug 2013
    McDonald PA
    Cooler and kit you can do yourself there are two good write ups. Tune I assume you would need to send out for. To overkill or find someone close to you that knew wtf they were doing
  16. #16 Re: 2007 gxp
    Aug 2011
    'Merica
    Unless you have HPTuners, you will have to have it tuned. Not sure on cost though. Cooler is easy and something you can do. Grab a shift kit from ebay for cheap.
  17. #17 Re: 2007 gxp
    Aug 2011
    'Merica
    You can get most stuff pretty cheap from Amazon or Ebay, but here is a great place to check out.
    http://tripleedgeperformance.com/Home-Page.html
  18. #18 Re: 2007 gxp
    new britain, ct
    you can find more information on a site dedicated to the LS4 platformed car.
    http://www.gmls4.com/index.php/board,14.0.html
    and yes, it is an HD trans.
    07 Black GXP.
  1. 2007 gxp
    By YELLOWBIRD in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 08:57 PM
  2. 2007 GT first car.
    By ragedsparrow in forum Introductions/Noob Questions
    Last Post: 06-17-2011, 12:50 PM
  3. my first gxp, 2007
    By buckslayer in forum Introductions/Noob Questions
    Last Post: 06-14-2011, 05:50 AM
  4. New from TN - 2007 GT
    By RotyP in forum Introductions/Noob Questions
    Last Post: 01-07-2011, 02:23 PM
  5. New 2007 GP GXP
    By Neanderthal in forum Off Topic Discussion
    Last Post: 11-21-2009, 06:13 PM
