Thread: Superchargers
Results 1 to 11 of 11
  1. #1 Superchargers
    GT Level Member TJeno's Avatar
    Jun 2012
    Ames, Iowa
    Do most guys here run stock ones, or are a lot of you on aftermarket superchargers? I've heard some of the older (and even newer) superchargers tend to 'go out' around 150K on a lot of these vehicles, is there any truth behind that?
  2. #2 Re: Superchargers
    Nope. If anything it's the coupler that goes out and that's a easy fix. And unless your going custom there is no aftermarket sc pure say.
    04 Comp G.
  3. #3 Re: Superchargers
    Jan 2014
    AR
    I think most guys know turbo is the next practical step up from the M90. Keep fresh oil in the stock one and it will for sure outlast the transmission.
  4. #4 Re: Superchargers
    Jun 2012
    Ames, Iowa
    Quote Originally Posted by idrivejunk View Post
    So, can the M90 hold it's own, or do most of the relatively serious guys step up to the turbos?
  5. #5 Re: Superchargers
    Texas
    Quote Originally Posted by TJeno View Post
    Most stay with the blower cause they can't afford the turbo and everything associated with it. However, those that do upgrade never regret it. The car becomes a different animal to drive and puts you on a whole other level.
  6. #6 Re: Superchargers
    Jun 2012
    Ames, Iowa
    Thanks, guys. Just kinda getting in on the automotive scene, trying to get a feel for popular options for these cars. I appreciate the help.
  7. #7 Re: Superchargers
    Jan 2014
    AR
    Well, I'm mostly a bodyman so I would have to research here to say where, power-wise, the stocker leaves off and the turbo prevails. A good idea would be to establish how fast you want to be then price setups then meet in the middle wherever your budget lies. Serious power means a huge investment in supporting mods, and the cars aren't worth much so you have to be careful and plan the buildup to reduce unnecessary spending.
  8. #8 Re: Superchargers
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Not to thread-jack but this kind of applies. Are there other superchargers than the Gen 1 (m62), gen 3 (97-03) and Gen 5 (04-08)? Are the other generations on different cars or do they only go by odd numbers? Just something I've always wondered.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  9. #9 Re: Superchargers
    TVS is a gen VI which is an even number.
    I cannot speak as to which gen the 3800 M62s were, but I can say, there were likely considered two different gens as they added a coating for the later years.
  10. #10 Re: Superchargers
    Buffalo, NY
    huh didn't know there was a gen VI. was just curious thanks.
  11. #11 Re: Superchargers
    92-93 S1 SC 3800 was M62 Gen 1 or 3 I honestly forget at this point. Uncoated rotors, coated body of charger with thermal paint
    94-95 S1 SC 3800 was M62 Gen 3 or 5 again.. who really cared back then. The difference in this version is that the rotors were coated and the thermal paint remained on the body of the charger to help disipate heat.
    96-97 S2 SC 3800 was M90 Gen 3 had a vaccum tree by the TB, thermal paint on housing.
    98- S2 SC 3800 was M90 Gen 3, had no vacuum tree by TB and no thermal paint on housing.
    04-08 S3 SC 3800 was M90 Gen V with better rotor coating and slightly better efficiency.
    The M62's used on Cobalts is not the same M62 as the 92-95 S1 SC 3800 version of the M62.
    The M distinction was used with a number that explained how much air was displaced in cubic inches per revolution. M62 moves 62 ci of air per rev, M90 moves 90 ci.
    On modding, reality is .. in the long run a turbo would be cheaper than all the stuff you need with an SC to be anywhere near the same power level. on either you need a built trans to handle it and parts for the transmissions are becoming hard to find like unobtanium.
  1. Superchargers
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 01-18-2011, 12:48 PM
  2. New to superchargers
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2009, 11:35 AM
  3. How Much Do Whipple Superchargers Add
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-22-2008, 10:38 PM
