Thread: Gaskets - lamps
Results 1 to 3 of 3
  1. #1 Gaskets - lamps
    Feb 2014
    United States
    1. Does the large frame member have to be removed/lowered to replace the oil pan gasket?
    2. How in the world do you replace lamps in the dashboard computer module?
  2. #2 Re: Gaskets - lamps
    St. Louis
    No, but you do need to jack the motor up and support it so the pan can clear the crankshaft.
    For the DIC, the dash bezel that runs around the stereo/speedo needs to come off. It's clipped in. Once removed the DIC should have it's own clip that allows it to be removed. Not knowing what year/model car you have I can only speak on the 97-03 GT's. Not sure on the 04+ cars.
  3. #3 Re: Gaskets - lamps
    Feb 2014
    United States
    Thanks. After checking the I-net for pan gasket replacement I decided it's more than I want to do.
    I have taken the DIC out in the past but it seems to me the lamps were hardwired in. Its been a while so don't quite remember. The car is a 99 GTP.
  1. running lamps
    By runn141 in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2012, 09:27 PM
  2. Need Help/Suggestions on Stop(Brake)Lamps/Interior Lamps/Cig. lighter.
    By Bulletproof Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2011, 01:51 AM
  3. Need help with stop lamps, interior lamps!
    By Bulletproof Gtp in forum Audio, Security & Visual Electronics
    Last Post: 09-15-2011, 05:07 PM
  4. Fog lamps ????
    By vondoom88 in forum Visual/Body Modifications
    Last Post: 10-19-2010, 05:39 PM
  5. looking for new fog lamps
    By ayman in forum Visual/Body Modifications
    Last Post: 04-03-2008, 11:30 AM
