Thread: 2008 Grand Prix HID headlights flickering
Results 1 to 5 of 5
  1. #1 2008 Grand Prix HID headlights flickering
    Oct 2012
    Saskatchewan
    put HID's in my car a while back and they do flicker if its not dark enough I figured its from the daytime running lights don't send enough voltage and they flicker and piss around, now when I originally hooked them up I used the harness to draw power from the battery and it still did the same thing except I could hear the relay kicking in and out, so I unhooked the harness and directly hooked them up. any ideas on how I can get rid of this problem I have to turn my lights on to eliminate this problem and I drive mostly with 1 headlight in the day time, and if I do straight driving from daylight till after dark I cant get the second light to come on and its really starting to piss me off.
  2. #2 Re: 2008 Grand Prix HID headlights flickering
    Dec 2010
    DMV
    Sounds like crappy ballasts
    Sent from my HTC One using Tapatalk
  3. #3 Re: 2008 Grand Prix HID headlights flickering
    Oct 2012
    Saskatchewan
    nah its something in the system causing it, iv got a set I paid around $200 for and a cheap set from ebay on my high beams and they work flawless and I also tried switching the ballasts around with still same effect
  4. #4 Re: 2008 Grand Prix HID headlights flickering
    Jul 2010
    Coquitlam,BC,Canada
    Possibly need two of these.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: 2008 Grand Prix HID headlights flickering
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Can't turn the DRL off? I know the 04+'s are different. If not try putting some electrical tape over the sensor so that it doesn't register and you can control them manually.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  1. Replace stock headlights 2008 grand prix
    By Jtpie in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2012, 08:49 PM
  2. 2008 grand prix
    By khayes in forum Introductions/Noob Questions
    Last Post: 05-27-2011, 06:34 PM
  3. What to look for? 2008 Grand Prix?
    By Importz in forum General Tech Discussion
    Last Post: 03-09-2011, 10:47 PM
