Thread: Broken dogbone bracket
Results 1 to 13 of 13
  1. #1 Broken dogbone bracket
    Mar 2014
    SE PA
    While changing my trans mount today, I went to remove the dogbones so I could raise the engine. Turns out that my passenger side dogbone bracket snapped right off the engine. Does anyone know what the bracket is attached to? Is it the LIM or the actual head? I couldn't really tell just looking at it.
  2. #2 Re: Broken dogbone bracket
    Apr 2012
    Bancroft. Ontario, Canada
    where exactly did that come from?
  3. #3 Re: Broken dogbone bracket
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I believe it bolts to the LIM, look for the bolts you can see the one next to number 4 injector, just unbolt the bolts then go find one at a junkyard.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Broken dogbone bracket
    Apr 2014
    CT
    its bolted to the head. the LIM wraps around it.
  5. #5 Re: Broken dogbone bracket
    Apr 2012
    Dayton, OH
    Either way, simple fix.
    2012 F150 STX
  6. #6 Re: Broken dogbone bracket
    pick up a l67 coil bracket / strut mount, its cast steel and will never break.
  7. #7 Re: Broken dogbone bracket
    This
    04 Comp G.
  8. #8 Re: Broken dogbone bracket
    May 2013
    illinois
    have someone that can tig box in the driver side aluminum mount and get rid of the passenger side mount all together looks much nicer
  9. #9 Re: Broken dogbone bracket
    Mar 2014
    SE PA
    Ok good, i thought that it was cast onto the LIM/head and then I'd have a big problem. I was kind of hoping it was cast on the head just so I'd have an excuse to top swap
  10. #10 Re: Broken dogbone bracket
    it just bolts to the side of the head. you swap your icm and coils on the l67 bracket and ditch yours.
  11. #11 Re: Broken dogbone bracket
    Mar 2014
    SE PA
    Does anyone have a spare one laying around/a part number? Otherwise, last time I checked the junkyard, there was an older gtp sitting in the lot so I'll just go pull one
  12. #12 Re: Broken dogbone bracket
    Apr 2014
    CT
    If you dont take off the uim you have to use a combination wrench to pull the right bolt. 1/8 turn at a time! I was able to get a socket on the left.
  13. #13 Re: Broken dogbone bracket
    Mar 2014
    SE PA
    Good advice! I might take off the uim just to see how it's looking though
  1. Broken GM Engine Mount Strut Bracket
    By chevy350 in forum General Tech Discussion
    Last Post: 02-28-2015, 06:05 PM
  2. Broken Torque Mount Bracket
    By CoolHandLuke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2014, 11:14 PM
  3. How to remove left-side dogbone bracket
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 06-20-2013, 07:25 AM
  4. Broken engine bracket
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-14-2013, 08:48 AM
  5. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
