Thread: before I f this up
Results 1 to 4 of 4
  1. #1 before I f this up
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So i'm putting my struts together today and want to double check before I get them together and have to take them apart. The tighter coiled springs are the front springs right?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: before I f this up
  3. #3 Re: before I f this up
    Oct 2011
    Toledo, OH
    Also you'll find that they really only fit one way on the upper strut mounts and the lower spring seat.
    7"
  4. #4 Re: before I f this up
    Buffalo, NY
    Thanks guys managed to get them together now just have to find time to install them.
