Thread: Gas tank filler neck
Results 1 to 18 of 18
  1. #1 Gas tank filler neck
    Feb 2013
    Woodbridge NJ
    So my son totaled his '04 GT on Tuesday. Just before the accident he had filled the gas tank. So we are wanting to siphon out the gas. Does anyone know if the filler neck has any type of anti-siphon device in the neck? I know I can remove the fuel pump and siphon from there but would rather just do it from the filler neck if it is possible
    Don
    2004 GT1
  2. #2 Re: Gas tank filler neck
    They have a screen, you won't be able to get a tube in there.
  3. #3 Re: Gas tank filler neck
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Gas is really liquid gold isnt it. Just pull the pump and do it that way, depending on the size of the screen idk if you could just jam something through it.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: Gas tank filler neck
    open the hatch in the trunk pull the pump, suck it out from there.
  5. #5 Re: Gas tank filler neck
    just had a thought, take the fuel line off the fuel rail and then turn the key to run, gas will pump out the line into a can or what ever you got, another car? if you cut the line, im sure you can push a rubber line onto it. then lead it to the other tank.
  6. #6 Re: Gas tank filler neck
    Feb 2013
    Woodbridge NJ
    Okay then thanks guys. Scotty will that actually work? Does the fuel pump work the full time that the engine is cranking? And I am not sure that the battery / starter will endure pumping 17 gallons of gas. I will just pull the pump and be done with it.
    Don
    2004 GT1
  7. #7 Re: Gas tank filler neck
    dont crank it, just turn the key to run it will flow gas.
    i remembered billboost telling someone to do that, and ive seen vid of it. guy was flow testing his pump, same way tho.
  8. #8 Re: Gas tank filler neck
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    wont the fuel pump relay shut off after a few seconds....
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  9. #9 Re: Gas tank filler neck
    the injectors shut off. the pump is always pushing line pressure.
  10. #10 Re: Gas tank filler neck
    Feb 2013
    Woodbridge NJ
    Well if I can get the hood open I may just try this. Would definitely be easier than swallowing gas
    Don
    2004 GT1
  11. #11 Re: Gas tank filler neck
    if you have a fuel filter on this car, you pop off the plastic clips side on the filter, and push a hose on the tube there, that would also work.
  12. #12 Re: Gas tank filler neck
    Feb 2013
    Woodbridge NJ
    Okay so here is how we did it. I found a video on how to do this https://www.youtube.com/watch?v=0WRYOv80DZs. I had to do it a little different though since the return hose nipple had been broken off in the accident. What I did was lower the rear seats and removed the fuel pump access cover in the trunk. I removed the fuel outlet hose (rear most hose) and attached a clear rubber hose to the pump. I turned the key on but the pump only ran briefly. So I followed the video and removed the fuel pump relay and installed a jumper wire from pin 30 to pin 87. The pump ran constant and we pumped the gas from the Grand Prix right into the tank of the Impala. Way faster and easier than siphoning into a gas can and then transferring into the tank. And no gas aftertaste to deal with. Thanks Scotty for the heads up. I would have never thought of doing this without your help. I think I am going to hang around here even though the GP is gone. Great bunch of guys here
    Oh I forgot to add that there is indeed some obstruction in the filler neck. The siphon hose seemed to stop just before entering the tank
    Don
    2004 GT1
  13. #13 Re: Gas tank filler neck
    that new cars engine is used in GP's and the body has about the same issues, so stick around, you'll still find help here.
  14. #14 Re: Gas tank filler neck
    Feb 2013
    Woodbridge NJ
    I plan to. The Impala forums are informative but there is way less traffic over there. So finding answers is not so easy. Plus it seems that there are a lot of folks that ask one question, find there answer, never post the end result, and then are gone forever. I do believe that this forum will help me a lot more than the Impala forums will be able to
    Don
    2004 GT1
  15. #15 Re: Gas tank filler neck
    same reason im over here yet own a regal lol the regal site is rather dead and slow.
    the car specific sites are real good for how to's for stuff that only applies to that car tho. interior work and stuff like that.
  16. #16 Re: Gas tank filler neck
    The pump turns off too. Jump the relay and it'll pump constant.
  17. #17 Re: Gas tank filler neck
    Aug 2013
    McDonald PA
    Well if the car is totalled why not just punch the screen out? Or drop the tank with the filler neck on it. And doesn't 04 still have trunk access to the pump?
  18. #18 Re: Gas tank filler neck
    IIRC the screen is part of the fuel tank where the hose connects. So pain to punch through. Running the pump would go pretty easy.
  1. Replies: 2
    Last Post: 11-07-2012, 11:28 AM
  2. filler neck....
    By sheffy in forum General W body
    Last Post: 11-03-2011, 07:27 AM
  3. Gas tank and filler neck
    By mrfreez in forum General Tech Discussion
    Last Post: 09-27-2011, 08:23 AM
  4. gas filler neck
    By gpgt98 in forum General Tech Discussion
    Last Post: 07-23-2011, 01:19 AM
