Thread: HUD issues/oil pressure light on
Results 1 to 2 of 2
  1. #1 HUD issues/oil pressure light on
    SE Level Member chatbreaker's Avatar
    Mar 2014
    midwest
    So I just swapped a new engine into my car, the last one had a rod knock. I think the issue may be electrical, I'm hoping it's something as simple as a wire hooked up wrong, but here goes.
    After finishing my test drive last night, I ran into a few issues. Primarily, the speed on the HUD will go up and down as the engine revs up, if I tap the throttle the HUD will show increasing speed up to 50 mph. The oil pressure light also came on, which I hope is just electrical too, since it doesn't appear on startup until I tap the throttle and the HUD starts acting up.
    Any ideas? I wonder if the oil pressure switch and the transmission output shaft speed sensor wires may have gotten hooked up backwards, but I doubt it since they're 2 different shaped connectors.
    This really has me stumped.
  2. #2 Re: HUD issues/oil pressure light on
    Please post only one thread on the issue. Thanks
  1. low oil pressure light on and off
    By elejes in forum General Tech Discussion
    Last Post: 08-05-2012, 03:14 PM
  2. Fuel Pressure & Other Weird Issues
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 05:27 PM
  3. Fuel pressure issues (Delete)
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 10:26 AM
  4. oil pressure issues?common or not?
    By strykergxp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2010, 06:18 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
