Thread: Oil life
Results 1 to 11 of 11
  1. #1 Oil life
    SE Level Member Boilermaker894's Avatar
    Jan 2014
    Indiana
    So how true do I stay with the oil life on the D.I.C.? And at what percent do you recommend changing it at
  2. #2 Re: Oil life
    It's not right at all mostly. I just changed mine every 3000 with the cheapest stuff I can find
  3. #3 Re: Oil life
    Life monitor is not very acturate at all. I can be at 2000 miles and it will say 60% in the summer months.
    Go by miles driven or months, which ever you wish. So 3,000 miles or 6 months, something like that.
  4. #4 Re: Oil life
    Call me old fashion but I just look at the sticker in the windshield and change it when its close.
    04 Comp G.
  5. #5 Re: Oil life
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I change it every 3k or 3 months whichever is first.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Oil life
    i set my trip to zero when i change my oil, and leave it on trip. when i see its close to 3000 or just past it, i know to change it again.
  7. #7 Re: Oil life
    I use to do this but then I found myself randomly wanting to reset it and couldn't control myself from doing it lol
    04 Comp G.
  8. #8 Re: Oil life
    Apr 2012
    Dayton, OH
    this
    2012 F150 STX
  9. #9 Re: Oil life
    i have no idea what my oil life is at right now, and its at least 2 oil changes deep with out resetting it.
    i just leave my dic set to avg mpg. i dont even care to see boost. i can hear its working lol.
  10. #10 Re: Oil life
    Jan 2014
    AR
    35-40% is usually around 3-4,000 miles. I actually watch mine, and not the odometer. It calculates several factors and won't match the miles method but it IS consistent in it's opinion. In my opinion, whoever has everybody thinking today's oils can only go two or three thousand miles in a roller cammed engine ... must be working at a refinery. I change mine at 35-40% "oil life" though, because I drive almost every mile in heavy stop-and-go traffic.
  11. #11 Re: Oil life
    Jul 2013
    Cranston, RI 02921
    The very process of changing oil is damaging to the motor. I'm NOT trying to start a flame war, but here's what I do:
    1) What ever oil you use, I suggest filling the new oil filter before screwing it on. This helps reduce the amount of time the engine is running without oil after it's started. Don't believe this helps, try it both ways and watch the oil pressure gauge.
    2) I use the cheapest FULLY synthetic oil. Synthetic oil lasts much longer than traditional oil and it flows better when the engine is cold. I usually go around 10,000 miles between changes. My car and my wifes both have over 200,000 miles. This means fewer oil and filter changes.
    3) Use the correct viscosity for the motor. This impact engine life and mileage. Sometimes it can be hard to find 5w synthetic oil. Look for the right oil.
    4) Only driving short trips can be hard on the oil. For example if you commute a half mile to work and back each day, condensation can develop because the motor never really heats up. You may see the oil cap looks like it's coated in milk. That's a sign of water or condensation. Synthetic oil doesn't do as well with condensation as conventional oil. If you only make short trips change the oil via the calendar and not the odometer.
    Why did I come up with this strategy? When I was in school my auto mech teacher told me the story of when he was in Vietnam. His team was responsible for keeping a bunch of huge generators running. The directions said they needed to be shut down and have the oil and filter needed to be changed every 8 hours and rebuilt every 500 hours or so. He ignored the maintenance recommendations and only changed the oil once a day instead of 3 times a day. It turned out that his generators lasted longer than everyone elses and looked a lot better during the rebuilds. The very act of draining the oil, and then restarting was more destructive to the motors. He also said he rested a lot better, not having to get up and change the oil every night. He also went on to explain that an unchanged filter will eventually plug up. The holes in the filter become smaller and smaller over time restricting oil flow as they become plugged with dirt. I've had no problem going every 10,000 miles between changes. I'm a big fan of synthetic oil because it flows better when starting the motor. http://www.edmunds.com/car-care/stop...-your-oil.html
  1. oil life
    By tegbir in forum General Tech Discussion
    Last Post: 09-10-2012, 08:43 PM
  2. Engine Oil Life
    By eshina17 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2012, 01:25 AM
  3. Oil Life
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2010, 07:32 AM
  4. oil life?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-11-2009, 12:40 AM
