Thread: Need some advice on replacing a window motor and/or regulator.
Results 1 to 6 of 6
  1. #1 Need some advice on replacing a window motor and/or regulator.
    SE Level Member mngtp's Avatar
    Crystal, MN
    We have a 1999 GP GTP 2 door. The driver's side window had been rolling up slower and slower, it did go down fine. Two days ago something broke, sounded like a cable broke or something. The window will not stay up on its own now. Shutting the door or driving will cause the window to work its way down. I removed the interior door panel and the cables are loose. The window will go up now. I can shimmy the window up by hand, its almost like its off track. I wedged some cardboard in the door to hold the window up for now.
    Im wondering if I need to replace both the window motor and regulator or just one of the two?
    Are there any rivets that I might have to deal with or is it just nuts/bolts that hold everything together?
    How difficult will this repair be?
    Cost is an issue, but this needs to get fixed along with a few other items.
    Thanks in advance for any help/advice.
    HIS: 1999 Pontiac Grand Prix Coupe GTP: 245,xxx miles and counting, 4" HD intake, 17" '06 Grand Prix GTP Rims
    HERS: 2005 Chevrolet Equinox LS: stock for now
  2. #2 Re: Need some advice on replacing a window motor and/or regulator.
    The regulator is bad
  3. #3 Re: Need some advice on replacing a window motor and/or regulator.
    The regulator is bad, but the motor can also be tired. The price for a new reg/motor is low enough that you pick it up as a unit. To remove/install. It's a few 10mm bolts after the panel is off.
  4. #4 Re: Need some advice on replacing a window motor and/or regulator.
    Crystal, MN
    Ok. I will probably just get it as a unit then. Its just $20 more with the motor. It would just be my luck that the motor is tired or bad too.
    Thanks for the help.
  5. #5 Re: Need some advice on replacing a window motor and/or regulator.
    Make sure you buy the correct side. But .. $35/BO for regulator and motor.
    http://www.ebay.com/itm/2002-Grand-P...r#ht_44wt_1153
  6. #6 Re: Need some advice on replacing a window motor and/or regulator.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Replace the whole unit. Its really not bad at all. Took me an hour. Probably would only take 20 mins if I hadent been distracted by a lady friend at the same time.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. Window regulator or motor?
    By gypsyjon in forum General Tech Discussion
    Last Post: 08-13-2012, 09:14 PM
  2. Replacing window motor/regulator, need help...
    By Just2Sweet in forum General Tech Discussion
    Last Post: 06-15-2011, 07:31 PM
  3. Window Motor Regulator
    By cutiger80 in forum General Tech Discussion
    Last Post: 12-15-2009, 09:09 AM
  4. Window regulator/motor
    By m1sterb0b in forum General Tech Discussion
    Last Post: 11-20-2009, 01:38 PM
  5. Window motor and regulator - how difficult?
    By Coogles in forum General Tech Discussion
    Last Post: 05-07-2008, 09:14 PM
