Thread: Headlight brackets
Results 1 to 6 of 6
  1. #1 Headlight brackets
    Feb 2014
    Colorado
    Hey everyone, I've had my '02 GP for about five years now and finally joined a forum. First topic on my mind: headlights. I just removed both headlight assemblies and fitted new Sylvania Ultra bulbs. I go to put the headlight assemblies back in, and they don't fit in right and are crooked and misaligned and look bad. How can I get around this problem?
  2. #2 Re: Headlight brackets
    Did you make sure that the headlight "tabs" are in the correct slots on the METAL body bracket that is welded to the car??
    If the 2 tabs are not in there holes, the headlights will not line up correctly.
  3. #3 Re: Headlight brackets
    Feb 2014
    Colorado
    Yup, they are in there. There's just two right: one for the corner lamp and one on the very inside behind the grille?
  4. #4 Re: Headlight brackets
    Apr 2013
    White Lake
    Go to youtube and look up 1Aauto Grand Prix headlights, I just watched it few day's ago because I noticed my brother put his headlights in wrong.
  5. #5 Re: Headlight brackets
    Feb 2014
    Colorado
    Thanks! If nothing else works I'll just buy some nice aftermarket units.
  6. #6 Re: Headlight brackets
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by Kellson View Post
    I wouldn't use aftermarket brackets. They cause some annoying headlight bounce. My drive side headlight doesn't let the outside tab go into the proper hole. I just tightened it down then readjusted the lights to be level. The trick to getting the outside on is make sure the inner one will be lined up and side the whole unit until the outside one goes in. At least that's how I do it.
    2012 F150 STX
    - Gonna be a race truck
  1. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
