Thread: Coolant leak
Results 1 to 10 of 10
  1. #1 Coolant leak
    Feb 2014
    Colorado
    Hey everybody, it seems my '02 3.1L has a coolant leak. I can smell the coolant steaming off. NO visual signs of a leak though…what should I inspect to find and repair this leak? Btw the engine has just over 100k.
  2. #2 Re: Coolant leak
    A likely cause is intake gaskets, or maybe the thremostat housing gasket.
    Both should be replaced at 100k anyway. The intake gasket are a very common failure and if not taken care of can destroy an engine.
  3. #3 Re: Coolant leak
    Feb 2014
    Colorado
    Alright, I'll look into that, I replaced the thermostat last summer—can't feel any moisture around the housing anywhere on it now.
  4. #4 Re: Coolant leak
    Jun 2011
    Texas
    Check around the water pump, throttle body hoses, and radiator also. The intake gasket is the most common leak. It is always a good idea to replace the distributor O-ring or oil pump drive O-ring the same time as the intake.
  5. #5 Re: Coolant leak
    Aug 2013
    arlington, tx
    I'd also check those notorious coolant elbows by the water pump...
  6. #6 Re: Coolant leak
    Lower intake manifold gasket is the most likely suspect. luckyg817. There are no coolant elbows on his car.
  7. #7 Re: Coolant leak
    Feb 2014
    Colorado
    No coolant elbows on the 3.1? That's great news!
  8. #8 Re: Coolant leak
    Aug 2013
    arlington, tx
    Oh really? Well then lucky you. Haha. One less thing to worry about.
  9. #9 Re: Coolant leak
    lim and heads leak on those engines. either one could be the leak.
    not so lucky really.
  10. #10 Re: Coolant leak
    Aug 2013
    arlington, tx
    Neither ones of those are any fun. I had to swap both on mine but mine is an 04.
  1. Coolant Leak
    By blackthunder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2013, 09:56 PM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Bad coolant leak** Need help...
    By 3R1CD4V15 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2012, 04:20 PM
  5. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
