Thread: bouncing suspension
Results 1 to 8 of 8
  1. #1 bouncing suspension
    SE Level Member buckslayer's Avatar
    valparaiso,IN
    I have bad news. My 2007 GXP was in an accident and was determined to be totaled. But I bought a 2008 GXP I I have noticed the ride is extremely bouncy. Feels nothing like my 07. Any thoughts.
  2. #2 bouncing suspension
    How many miles? I'll take a look at the strut mounts and make sure your struts are still Billstein and weren't replaced with something cheaper.
    04 Comp G.
  3. #3 Re: bouncing suspension
    Mercer, Pa
    They could be bad and just need replaced.
  4. #4 Re: bouncing suspension
    valparaiso,IN
    They are still billstein . 64000 and the tire are not Bridgestone potenza. Something is not right and I just bought it.
  5. #5 Re: bouncing suspension
    Nov 2012
    Madison
    Post a pic of the car. In your avatar the rear does look somewhat low.
    Could be the previous owner put some lowering springs on.
    That would make the ride maybe stiffer/bouncier than your old car.
  6. #6 Re: bouncing suspension
    valparaiso,IN
    The picture is of the one that just got wrecked. And there are no lowering springs because it sits higher it seems to me. I wonder if it is the tires. But maybe the struts are worn out. The ride is really strange. It almost makes me sick. I so want my other one back?
  7. #7 Re: bouncing suspension
    push down on each corner of the car, it should stop bouncing with in 3 bounces.
    or the tires could be egged out. try rotating them. see if it feels any different.
  8. #8 Re: bouncing suspension
    valparaiso,IN
    You don't rotate on this car as the front are a different size then the back. Tires wrong kind and way to soft may be the cause.
  1. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  2. RPMs bouncing when cruising
    By nukkinfuttz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2012, 07:05 AM
  3. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  4. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  5. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
