Thread: I think I have a cam? Help. Lol
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 102
  1. #1 I think I have a cam? Help. Lol
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    Soooo long story short I've had this car almost a year now. It has had a p0300 misfire code since day one. Idles very rough but drives like a new car when going down the road. The only time it doesn't have the lobing "camming" sound is the first 30 seconds after cold starting it. Basically I start the car and as soon as the PCM turns the climate control on I'll hear the ac compressor kick on and it starts idling like it's cammed. My mechanic thinks it has a cam but I want to know 100% what's going on with it. I have replaced the spark plugs, wires, and checked literally everything for misfires and vacuum leaks and check and replaced all gaskets. I've been at a stand still and it's frustration. I'll put some videos up if anyone wants to try and help lol. Basically my question here is what's the easiest road to go down to find out if the cam is stock or aftermarket. Even if I took it apart how would I know? The car is a 2000 GTP 3800 supercharged L67
    BOOSTIN
  2. #2 I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    I'll post a video as soon as possible
    BOOSTIN
  3. #3 Re: I think I have a cam? Help. Lol
    Florida
    Good chance that it is cammed. Pop the oil cap and see if you can see if the valve springs/retainers/seals are different (titanium retainers, yellow springs, or blue seals) That'd be a great indication that someone has messed with the valvetrain.
    Only way to be 100% sure is to pull the motor, and either pull the cam (lots of work) or pull the rear cover and see if the rear of the cam is scribed like so
    See how the cam has got the cam specs on it?
  4. #4 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    Ok thank you that actually helps a lot, I have a bunch of mods almost ready to go on the car but I don't want to mod it without knowing if it's cammed or not for tuning reasons and all that. Is it very difficult to take off the rear cover to look for any specs? The car had a cold air intake on it when I bought it also the valve cover gaskets and grommets were all new so I know someone had those off at the least.
    BOOSTIN
  5. #5 Re: I think I have a cam? Help. Lol
    Not really difficult but you have to pull the engine out to remove the rear cover iirc.
  6. #6 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    Sounds like a lot of work lol.
    BOOSTIN
  7. #7 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    Is there a lot to mess up if I continue to mod the car without finding out first?
    BOOSTIN
  8. #8 Re: I think I have a cam? Help. Lol
    Florida
    You do have to pull the motor. First time probably takes about 4-5hours to get the motor out. A little longer to get it back in. Once you've done it a few times, you can go from it running, motor pulled, issues fixed (my case broken flex plate) and back in and running in about 6-7hours.
    It's really not that hard to do. If you take the hood off (4 bolts) you gain a lot more space for the hoist.
  9. #9 Re: I think I have a cam? Help. Lol
    Florida
    But like Slick said, it's not hard to pull the cover and check, it's just getting to the cover.
  10. #10 Re: I think I have a cam? Help. Lol
    hangover park IL
    easiest way is to yank a valvecover, pull a rocker and put a dial indicator in the end of the pushrod and read the cam lobe lift and compare
    ~James~ Psychotic Gearhead
  11. #11 Re: I think I have a cam? Help. Lol
    Dec 2012
    troll land
    Have you checked coilpacks or icm? Possible its iac also. If it was a cam youd notice otjer things like power.
  12. #12 Re: I think I have a cam? Help. Lol
    Florida
    why has no one suggested checking boost levels? he is on a 3.5 pulley. someone with similar mods should be able to compare boost pressure to his at a specific RPM. a cam will lower boost pressure. by any chance what kpa or psi are you seeinng?
  13. #13 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    I've already replaced the iac, But I'm getting around Maby 8 spiking 10 psi under full throttle
    BOOSTIN
  14. #14 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    What's kpa?
    BOOSTIN
  15. #15 Re: I think I have a cam? Help. Lol
    May 2012
    Where winter never ends
    kilopascels - measurement of pressure like PSI.
    2000 Regal - Winter Beater
  16. #16 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    Ok
    BOOSTIN
  17. #17 Re: I think I have a cam? Help. Lol
    May 2012
    Pull the valve cover, look and see if anything is different (Blue seals, different retainers) and if you really want to know pull a rocker and put a dial indicator in the end of the pushrod and read the cam lobe lift and compare to the stock lift.
  18. #18 Re: I think I have a cam? Help. Lol
    gardner,mass
    whats your vacuum like at idle?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  19. #19 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    That seems like a pretty good idea, I'm new to the pushrod thing. So which part exactly do I measure with the valve cover off?
    BOOSTIN
  20. #20 Re: I think I have a cam? Help. Lol
    gardner,mass
    Just check your vacuum. Stock should read around 18-22. If your cammed most likely you will be around 15.
