Thread: I think I have a cam? Help. Lol
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 102
  1. #81 Re: I think I have a cam? Help. Lol
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    yeah thats true, i do have a garage and tools, I'm just more worried about messing something up lol. and the video of that vs cam his tachometer stays completely still the whole video, mine jumps in between like 500-1000 rpm at idle and a lot of times when it drops low my dash lights and everything start to dim out.
    BOOSTIN
  2. #82 Re: I think I have a cam? Help. Lol
    Yup that's how mine sounds with the exception of the lifter noise I'm getting
    04 Comp G.
  3. #83 Re: I think I have a cam? Help. Lol
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    That is actually my build lol The VS cam isnt a large cam so idle wont move much but if you have a slight larger one, NIC, XP, IS2 cam and such it will, especially if not tuned. you might have a xp since it is the most common one. but lets not get ahead of ourselves and think there is a aftermarket cam for sure in there. i say tear apart the block if you have a cam great if you dont add one in there along with other goodies that have you have and change all gaskets, TQ all bolts properly add fluids. Then Start up.
    If You Cant Hear The Whine You're Too Far Behind...
  4. #84 Re: I think I have a cam? Help. Lol
    It'll be hard to mess something up just mark which pushrods and lifters come out which cylinder etc and be sure the cam is well lubed when you go to reinstall it. It's not a difficult process just a bit of time consuming. Give yourself a weekend and more importantly have plenty of beer and you can do it! Hell when I did my install I did it in my driveway and had no sort of awning or anything.
    04 Comp G.
  5. #85 Re: I think I have a cam? Help. Lol
    Buena Park Ca
    Just had that happened to me, i forgot to change my lifters even though i had my LS7 ones there lol
  6. #86 Re: I think I have a cam? Help. Lol
    Buena Park Ca
    Why do you need to organize the pushrods and rockers and such i didn't lol They aren't adjustable or anything so why would it matter if they are all the same?
  7. #87 Re: I think I have a cam? Help. Lol
    Something told me to wait and order new lifters but I wanted to save some time and money and reused my old ones and bam annoying valvetrain noise!
    04 Comp G.
  8. #88 Re: I think I have a cam? Help. Lol
    Piece of mind if anything so they go back into the same cylinder for wear and tear reasons. Personally I didn't lol but guys seem to recommend it.
    04 Comp G.
  9. #89 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    I really want my idle to be smooth and not bounce me around at every stop light, I know it's fun. But for my every day driver it's really annoying so if it is aftermarket what's my best cam option for a almost factory idle but still better performance?
    BOOSTIN
  10. #90 I think I have a cam? Help. Lol
    VS ftw
    04 Comp G.
  11. #91 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    Ya? I'll do some research on it. I can't just put it back to stock. In my books that would be a sin lol
    BOOSTIN
  12. #92 Re: I think I have a cam? Help. Lol
    http://shop.zzperformance.com/store/p/50-VS-Cam.aspx
    Very streetable. Exactly why I went this route vs a larger cam.
    04 Comp G.
  13. #93 Re: I think I have a cam? Help. Lol
    Florida
    Quote Originally Posted by GTP89 View Post
    Because all the parts wear to each other. It's a good idea to keep them all paired, especially the lifters as they will wear to their bores.
    I didn't change my lifters out either, though I do have one that is collapsed now. Can't hear it with the radio on so meh.
  14. #94 Re: I think I have a cam? Help. Lol
    Florida
    Vs cam is very streetable, but so is basically every cam there is. Sure the gas mileage goes down, and sure they react better with a different converter stall, but how awesome is it to roll around with an IS4 and an open dump?
    Side note, my cam is plenty streetable. Mileage went down some, but not much cruising. Plus is pulls strong to 6500
  15. #95 Re: I think I have a cam? Help. Lol
    GT Level Member aligater's Avatar
    london ontario canada
    Is it possible you have carbon build-up on the throttle boby blade and its messing with your idle? I've seen a few cars that just need a good cleaning.
    Also if your LIM gaskets are breathing thru the crankcase you might have a cylinder getting un-metered air that the computer can't account for.
    But if your dead set on tearing it apart to make sure, and your handy, changing all those gaskets. Is a good plan while your in there. But if everythings all good other than the burning curiiousity just pull the whole engine out and pop the flex plate and rear cover.
    It might seem like more work but way less cost on parts.
  16. #96 Re: I think I have a cam? Help. Lol
    Mercer, Pa
    VS cam
    Engine warm
    low idle
    In drive
    Sitting at light
  17. #97 Re: I think I have a cam? Help. Lol
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Tear it apart..LOL
    The answer to figuring this out as simply and quickly as possible was back on the first page, post #10 for those that missed it.
  18. #98 Re: I think I have a cam? Help. Lol
    Feb 2013
    Rockford
    i think thats what I'm gonna have to do, so with a degree tool i can accurately get the degrees of the cam just by taking the valve cover off? so far that sounds like the easiest way, i would just like to know so when i tune it its not off
    BOOSTIN
  19. #99 Re: I think I have a cam? Help. Lol
    Florida
    I think it has been said, but cam or not the way you go about tuning it is the same! If you have caught up on all maintenance and sure there are no vac leaks then just start tuning.
  20. #100 Re: I think I have a cam? Help. Lol
    Dec 2012
    troll land
    Tip for organizing lifters and pushrods get a shoebox and poke six holes in a row on ech side of the bottom and number the pairs to correspond with the cylinders on engine. Then rubberband each lifter to the matching pushrod and slide it in the hole in the box that matches the location on the engine
