Thread: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
  1. #61 Re: NEED HELP! after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    SE Level Member JimSWylie's Avatar
    May 2013
    Newport, WA
    Awesome Thanks BTW your in box is full
  2. #62 Re: NEED HELP! after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Made some room
    Quote Originally Posted by JimSWylie View Post
  3. #63 Re: NEED HELP! after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Finally got ALL my issues fixed!
    Ended up getting a 2002 gp gt engine harness, and a 2000 gtp pcm.
    Had to relocate several wires, add the fuel pump resistor wire between the fuse/relay center and the pcm
    what a battle this has been, no codes popped up yet, ill drive a couple of days and see how she goes.
  4. #64 Re: NEED HELP! after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Thats good to hear now time to mod it
  5. #65 Re: New updates: after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Well After driving car the car a couple of days had a few problems-p0650=malfunction indicator lamp (MIL) control circuit, p0131=o2 sensor circuit low voltage bank 1 sensor 1, and p0300=random/multiple cylinder misfire detected. Weird ones-run very well up to about 3800 rpm and stumbles a bit but eventually takes off-suspected running out of fuel, trans shift point were all over the place, boost gauge on dic did not show up, incorrect gear ratio did not show up on the scanner, and Perf shift did not work at all.
    The scanner is fairly new to me and was playing around with it and found where you can pull the vin and to my surprise, the pcm was for a L36. Someone at the salvage yard or owner of the car must have changed it out not knowing. There were enough clues i should have figured it out on my own. So i swapped out with my 98 pcm and and back in business again
    Now almost everything works correctly- Perf shift works only at WOT and with neither dic or dash light coming on, at WOT first gear is smooth through shifting into second then around 4000 rpm stumbles a bit but picks back up and same with third, the codes that pop up now are- the incorrect gear ratio (which i already know why), p1671=MIL solenoid circuit and p1646=boost solenoid/5v reference c/evap vent circuit.
    Now doing a little searching and see what i can figure out.
  6. #66 Re: New updates: after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    I've done a lot of searching and all ive come up with is the pcm pin out for a 98. Cannot find one for a 2002 to compare. Nor pin out for engine harness plug where it plugs into the fuse relay/center. I believe that the 98-02 fuse/relay centers are the same except for the GTP's having having the extra relay #15 for the two speed fuel pump. But am not 100% sure. Are the pin outs the same on the 98-02 PCM'S?
    I'm still trying to figure out these last two problems:
    Can anyone shed more light on this and or have anymore info?
  7. #67 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Pcms will have the same pinouts
  8. #68 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Thanks for that, I thought so but wanted to make sure.
  9. #69 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Is ur blower bypass valve solenoid plugged in
  10. #70 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Ya its plugged in but im suspecting its not wired right to the pcm
    I used the 02 gt harness and moved the bbv plug and wires from the 98
  11. #71 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Found almost all wire information needed to trace this down but have not found pin out info for the pcm plug that connects to the fuse/relay panel yet.
  12. #72 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Well i purchased a snap-on Sollus Ultra scan tool, cant believe all the info that's packed into this thing. Still learning how to use all the features.Anyway rewired bbv now im getting full boost, lost all other dtc's except mil control circuit
    and only current one is several cylinder misfires, still gonna look into this one later but run out of time today.
  13. #73 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Nearing completion. Soon to be mod time
  14. #74 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Yes Yes Yes
  15. #75 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Btw my friend is interested in the hud. Only thing is it looks like youll still have ro pay shipping on tb
  16. #76 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Finally got all of the electrical bugs worked out, got a hold of a 2000 gtp fuse/relay box, pcm, bcm, and digital dic, all is well now.
  17. #77 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Bet ur relieved
  18. #78 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    May 2013
    Newport, WA
    Ya its a pretty good feeling, took lots of patience to get everything to work right.
  19. #79 Re: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Dec 2012
    troll land
    Raced anything yet?
  1. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  2. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  3. Work Gripes About My First World Problems
    By SlowNA06 in forum The Rant Forum
    Last Post: 02-06-2012, 01:04 PM
  4. Will a 98 Key Fob work on a 2002
    By timboku in forum General Tech Discussion
    Last Post: 05-13-2010, 01:36 PM
  5. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
