Thread: Lowering
Results 1 to 12 of 12
  1. #1 Lowering
    GT Level Member GrandPriest24's Avatar
    Jan 2013
    Michigan
    Im looking for coilovers but cant seem to find any on the internet anyone selling some on here or know where i can get some?
  2. #2 Re: Lowering
    ZZP
    Intense
    Or held Motorsports
    You didn't look to hard
    04 Comp G.
  3. #3 Re: Lowering
    Jan 2013
    Michigan
    for coilovers?
  4. #4 Re: Lowering
    Yup
    04 Comp G.
  5. #5 Re: Lowering
    I'll help you out. Or make your own there's a write up floating around here
    http://shop.zzperformance.com/store/...for-Wbody.aspx
    http://intense-racing.com/Merchant2/...y_Code=3800_BS
    04 Comp G.
  6. #6 Re: Lowering
    Jan 2013
    Michigan
    Thank you
  7. #7 Re: Lowering
  8. #8 Re: Lowering
    Nov 2011
    NY
    Arraut MS is great, you let em know what you're looking for as far as ride and they're very helpful. Same products as being sold by others, sometimes 1/2 the cost. I like their set-up for the coilovers and would probably pair that with Bilsteins for a great ride. Do your research as to spring rate and if you want a good ride that'll last, pay the exra $$$ to have to strut rate matched to the springs. Arraut MS has great trailing arms and stuff too. If you're going to stiffen up the suspension and lower it I would suggest upgrading all components, I.e., sways, strut tower braces, poly bushings all around, check your engine and tranny mounts, strut mounts, etc. To do it right, expect a 2-3 grand overall : )
    Good luck!
  9. #9 Re: Lowering
    Dec 2010
    ATL,Georgia
    Another thing is if you buy them from Arraut you can choose your spring rate, which you can not do when buying through ZZP or Intense. Just something to think about.
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  10. #10 Re: Lowering
    Springs are cheap anywats
    04 Comp G.
  11. #11 Re: Lowering
    Dec 2010
    ATL,Georgia
    Ya but its nice that they will let you choose them ya know, plus they will answer any questions about spring rate you are looking for.. i was going to snag some from them before i bought the bags.
  12. #12 Re: Lowering
    not if you want good ones. hyperco and swift springs are the opposite of cheap.
  1. Lowering my car
    By 1996pontiac in forum Brakes/Suspension/Chassis
    Last Post: 01-23-2013, 05:14 PM
  2. Lowering car?
    By bbptech in forum Visual/Body Modifications
    Last Post: 03-23-2010, 08:00 AM
  3. Lowering Car
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2009, 07:26 AM
  4. lowering
    By keenan00gtp in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2009, 08:39 PM
