Thread: 2002 Gtp starts but won't idle
Results 1 to 12 of 12
  1. #1 2002 Gtp starts but won't idle
    SE Level Member ItaliaGTP35's Avatar
    Jul 2013
    Chicago IL
    Ok I'm in Chicago and we are frozen. So today I go out start it up and let it run for 30 min shut off went out in my other car came home and when I start the Gtp it starts but shuts off before it can idle. I have a few ideas what it could be but want more input Help she needs to run
    Thanks
    Sent from my iPhone 5 GOT WHINE?
  2. #2 Re: 2002 Gtp starts but won't idle
    St. Louis
    Have you tried feathering the gas once it does start? Might just be a sticky IAC causing it to choke.
  3. #3 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    I have and it still shuts off after that as well
  4. #4 Re: 2002 Gtp starts but won't idle
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    will it idle at all or does it shut off immediately" could be a faulty coolant sensor. Does it smell like its flooded? You might try opening your air filter have someone start it while you spray starting fluid in it. See if it will stay running long enough to build up some heat. Could be frozen moisture in the TB holding the valve closed. I would almost bet its ice somewhere.
  5. #5 Re: 2002 Gtp starts but won't idle
    turn the key to run, then check for fuel pressure at the rail.
    if its got pressure, try to start it, leave the key to run when it stalls, recheck for fuel pressure again. if its got no pressure id think the pump bit the dust. beating on the bottom of the tank can sometime make them work again. if it does works, its time for a new pump, dont trust it any more.
  6. #6 Re: 2002 Gtp starts but won't idle
    Security light flashing??
    That will shut it off after 3-5 seconds of running.
  7. #7 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    I think it might be I don't remember at the exact moment. But if it is how do I fix that
  8. #8 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    That's what it does it starts no problem but 5 seconds it shuts off like I said I don't recall the security light but I want to say yes it was
  9. #9 Re: 2002 Gtp starts but won't idle
    You can try locking and unlocking the car from outside, then starting it.
    If you have a second key or a valet key, try one of them.
    Thats if the light is flashing, if it isnt the issue you got other idea's to go off of.
  10. #10 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    It doesn't idle at all so I should spray starting fluid in the throttle body???
  11. #11 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    Thanks everyone I'm going to try all these ideas out hopefully one works I just hope it's not the fuel pump. I honestly think it's the security thing or the TB or the fuel lines may be a little frozen I will keep you posted thanks again
  12. #12 Re: 2002 Gtp starts but won't idle
    Jul 2013
    Chicago IL
    Just wanted to let everyone know that SHES ALIVE all it turned out to be that the security system needed to relearn the key. Thanks again for all the advice. But I must say the 2013 nissan maxima that I rented is a very nice ride and fast too
  1. Rough idle when car starts?
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2012, 01:18 PM
  2. 2002 GT STarts and dies
    By BillBoost37 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-07-2012, 11:39 AM
  3. 2002 GT starts and dies engine warm
    By Bart40th in forum General Tech Discussion
    Last Post: 09-26-2011, 07:57 AM
  4. grand prix starts, will not idle, stalls.
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:20 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
