so my car had problems starting it just cranked, cranked, an cranked then start an after a message said reduced engine power came on an these codes are what came up when I ran them p0606, p1518, p0113.
http://www.obd-codes.com/p0113
http://www.obd-codes.com/p0606
http://engine-codes.com/p1518_chevrolet.html
the middle one for a bad pcm. that maybe the whole problem
what is a pcm? never heard of it
Powertrain Control Module
The car's computer.
that's not a cheap fix either
now can I drive it like this or no?
I would go and unhook the battery negative for a few minutes, hook it back up, and see if the codes pop back up.
While you can drive it like that, it's not a good idea to.
iv done that, I put a new battery in my car so everything reset itself
if its running ok you can, with all them codes id think the throttle is messed up maybe too.
you need a new pcm, its in the air filter box. or a used one from a junk yard, just get one from your same year. a few cross over years. not sure what you got.
you cant use a n/a pcm in a supercharged car, (or the other way) so make sure its the same as far as your engine too.
well I have a 2004 Pontiac grand prix gt 2
