Thread: Heat issue grandprix 2008 3.8
Page 4 of 4 FirstFirst ... 234
Results 61 to 71 of 71
  1. #61 Re: Heat issue grandprix 2008 3.8
    rocks? maybe dex boogers? were they brown?
    either way as long as the temp is right and you got heat, carry on right lol
  2. #62 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    Yes they were brown what are Dex boogers? Coolant it at 90C which is 194F is that a good temp.
  3. #63 Re: Heat issue grandprix 2008 3.8
    thats a good temp. why your heat feels so much better now.
    the old dex coolant leaves this snot like brown crap in the engine, even after a flush and changing to green coolant there will be some of the old dex that has boogered up broke free form inside and is floating around in the engine. its shows up on the rad cap a lot still on my car still.
  4. #64 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    Ha got you, thanks for everything. Why when I had it flush the heat was working good and then it just got weaker and weaker until I flushed the heating core again.
  5. #65 Re: Heat issue grandprix 2008 3.8
    if a shop did the flush theres a chance they didnt bleed it well. or you already had the air in the heater core. a flush wont fix air in the core. its air bound already. you need to refill it manually.
  6. #66 Re: Heat issue grandprix 2008 3.8
    Dec 2012
    Where 4T65E's were born
    Well he said they flushed it, and it worked great at first, slowly getting weaker and weaker over time. I'd say you have a lot of stuff floating around in the system, eventually getting trapped in the heater core.
    Sold.
  7. #67 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    We shall see how long it last for but I assume I should be good now. Anyways winter is almost done and I'm hoping my AC works fine as I had a leak last summer and had to replace the rad and then it was fine for abit and them stopped producing cold air and it turned out one of the metal copper pipe I believe got bent. Dam car always having issues with heat or AC lol. Thanks again I may be back
  8. #68 Re: Heat issue grandprix 2008 3.8
    knock on wood my a/c has worked since the day i got it. one of the few things ive not had to mess with.
  9. #69 Re: Heat issue grandprix 2008 3.8
    Apr 2015
    what temp does the electric fans kick on? i replaced the 3 relays and the temp sensor too. the fans do kick on when i turn the A/C on so they work. am i missing another sensor. i cant find anywhere what temp they turn on. because while sitting in traffic it goes up but i want know when. i think i found it. i think its 230 degrees so it must be normal on cars with electric fans seeing the temp gauge move alot because the fans dont run til than . its my first car with electric fans. i used to drive cars that had the old fans that run with engine so the temp gauge barely moved with them
  10. #70 Re: Heat issue grandprix 2008 3.8
    they come on at 212. do you have a torque app? if so see what the temps say on that.
  11. #71 Re: Heat issue grandprix 2008 3.8
    Apr 2015
    No I dont.
  1. 2008 Grand Prix heat is starting to fail
    By veener79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2013, 08:04 PM
  2. My 2008 GrandPrix GXP
    By Bobbie Graves in forum Introductions/Noob Questions
    Last Post: 01-09-2013, 10:05 PM
  3. 2000 grandprix gt tranny issue
    By mattstansbury in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2011, 09:33 PM
  4. Engine whine!! 2008 grandprix gxp 5.3 v8
    By tonio301 in forum 5.3L V8 (LS4)
    Last Post: 06-07-2011, 10:43 AM
  5. 2008 Grandprix 56K Miles-- Wheel Bearings replacement.
    By magickid in forum Tires & Wheels
    Last Post: 04-09-2011, 07:25 PM
