Thread: Obdii
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Obdii
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    that is inexpensive but you get what you pay for.
    go to autoenginuity.com.. This system will won't leave you lacking. click on the gm family. You can buy only what you need and expand to other brands at any date. for $230 it will do all you want plus
    ABS Automated Bleed Routine (ProLine Connector)
    Crank Variation Learn (click here for supported vehicles)
    Injector Flow Rate Programming (CAN-based Diesels)
    Key Fob Programming (click here for supported vehicles)
    SDM Setup and Part Number Programming (click here for supported vehicles)
    Idle Learn
    TDC Learn
    Tire Pressure Sensor ID Programming (via CAN-based Remote Control Door Lock Receiver
    2004 comp g
  2. #22 Re: Obdii
    GT Level Member hammerline81's Avatar
    Apr 2013
    Saskatoon, SK
    yeah, sounds like a good idea. I'm probably going to go with that. looks like there's a lot of stuff that i wouldn't even use right now but more options are better than less.
    2004 Grand Prix GTP Comp G
  3. #23 Re: Obdii
    Apr 2013
    Saskatoon, SK
    Quote Originally Posted by primem View Post
    Idle Learn
    TDC Learn
    I know this is an old thread but even if i buy the enhanced GM-family package on top of this scanner, it will NOT read Grand Prix ABS. they said that they still cant figure out how to read the codes, so I'm a little ****ed for that.
  4. #24 Re: Obdii
    Sep 2013
    Calgary, Alberta
    I'm surprized by that. This is a cut and paste from the gm portion of the site..."Our enhanced GM interface supports 6,400+ sensors selected from the engine, transmission, body, and chassis systems".
    Abs is under chassis.
    Launch has a new scan tool out for $350 that does powertrain, abs and airbag
    2004 comp g
  5. #25 Re: Obdii
    Apr 2013
    Saskatoon, SK
    Yeah, it kind of sucks that they can't read the Grand Prix's. I may have to look at that. I gotta fix up my Comp G.
  6. #26 Re: Obdii
    Quote Originally Posted by hammerline81 View Post
    My otc 9450 reads 04+ gp
  7. #27 Re: Obdii
    Apr 2013
    Saskatoon, SK
    It'll read the wheel speed sensor?
  8. #28 Re: Obdii
    It reads abs and air bag codes. It was like $80 on Amazon
  9. #29 Re: Obdii
    I live here. DirtDog's Avatar
    Jun 2012
    Link
  10. #30 Re: Obdii
  11. #31 Re: Obdii
    Jun 2012
    and it actually works....awesome. think i may grab one to.
  12. #32 Re: Obdii
    Sep 2013
    Calgary, Alberta
    That is a good price and otc is a very good brand. they make the gm oem factory scan tool so its would be a good choice for gm products.
    I was looking at this for $350
    http://www.launchtechusa.com/assets/products/CRP129.pdf
    2004 comp g
  13. #33 Re: Obdii
    Apr 2013
    Saskatoon, SK
    Thanks for the link. That's a really good price too!
  14. #34 Re: Obdii
    Apr 2013
    Saskatoon, SK
    I bought this reader and it's amazing... I'm so blown away by how much this thing can do. And for a **** tonne of models as well.
  1. obdii port
    By Taz Magister in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2011, 07:18 AM
  2. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  3. Obdii?
    By Viper in forum General Tech Discussion
    Last Post: 03-06-2010, 09:58 AM
  4. ECM To OBDII Connection
    By lstexan in forum General Tech Discussion
    Last Post: 02-07-2010, 03:05 PM
  5. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
