Thread: Trunk Courtesy Light Switch intermittent operation
Results 1 to 3 of 3
  1. #1 Trunk Courtesy Light Switch intermittent operation
    SE Level Member Crispykit's Avatar
    Apr 2013
    Canada
    Has anyone had there trunk light work off and on? Sometimes it comes on and sometimes not. I have tried activating the switch on the latch (rear compartment lid ajar switch) that is supposed to close the circuit but nothing happens. When it does come on turning the switch on and off does as should? Also tried testing ground on the switch but can't seem to find a good ground source. Any suggestions would be appreciated. If you can buy a new switch (rear compartment lid ajar switch) the GM part number might turn me in the right direction. The positive wire going to the light is the Orange/Black wire without the Entrapment Protection
    Crispykit 2001 GP GT
  2. #2 Re: Trunk Courtesy Light Switch intermittent operation
    Jun 2011
    Texas
    It is designed to only have the trunk light come on when the interior lights are on and the trunk is open. The positive battery feed comes from the BCM, the ground comes from the trunk switch
  3. #3 Re: Trunk Courtesy Light Switch intermittent operation
    Apr 2013
    Canada
    Ok that makes sense as when I had the car running (was checking the trunk ajar light on dash to see if it worked) the light was on.
    I guess everything is as it should be.
    Thanks for the heads up (I have been goofing with this for about three weeks and you fixed me up in less than a day).
  1. Intermittent P1571 and ABS/Trac Light On
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-10-2013, 10:16 PM
  2. courtesy light fuse keeps burning out.
    By turboeater in forum Audio, Security & Visual Electronics
    Last Post: 10-21-2011, 10:09 AM
  3. Courtesy light switch
    By sdully88 in forum General Tech Discussion
    Last Post: 01-30-2011, 08:11 PM
  4. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  5. info about headlight switch operation...
    By gtp40th in forum General Tech Discussion
    Last Post: 02-14-2010, 01:39 PM
