Thread: AC and Heat work on settings 1-4 but not 5?
Results 1 to 12 of 12
  1. #1 AC and Heat work on settings 1-4 but not 5?
    SE Level Member jshep105's Avatar
    Jun 2013
    Massachusetts
    Hello I drive a 2002 Grand Prix gtp and it blows hot on settings 1 through 4 but if I set it to 5 nothing happens (like it's set to OFF). Same thing happens with the AC.
  2. #2 Re: AC and Heat work on settings 1-4 but not 5?
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Blower motor Resistor under the dash most likely. About $75 when I replaced mine.
    Sent from my VS920 4G using Tapatalk
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  3. #3 Re: AC and Heat work on settings 1-4 but not 5?
    Dec 2012
    Where 4T65E's were born
    Are you sure? ^ Usually it's the resistor if it blows on 5 only.
    Sold.
  4. #4 Re: AC and Heat work on settings 1-4 but not 5?
    Oct 2012
    Orland Park IL
    I have seen it blow on 1-4 but not 5 before. It's a likely possibility.
    Sent from a corn field in IL.
  5. #5 Re: AC and Heat work on settings 1-4 but not 5?
    GTX Level Member blackflag's Avatar
    Virginia
    This.
    Basically your Q is the opposite of anything ive ever encountered. However, dont rule out the resister and ign switch.
    Any other funny things going on? Dic getting dim, clicking relays in dash, heated seats setting off relays?
  6. #6 Re: AC and Heat work on settings 1-4 but not 5?
    Oct 2012
    Orland Park IL
    Only reason I say is because we had a MC come into my work one day with this issue, and out of curiosity my manager metered everything out (we aren't supposed to work on cars necessarily), and tried a new blower motor too, ended up being the resistor. Opposite of how it normally fails, yes, but it is possible.
  7. #7 Re: AC and Heat work on settings 1-4 but not 5?
    Apr 2011
    Fargo
    When my resistor went it blew on 4-5 only
  8. #8 Re: AC and Heat work on settings 1-4 but not 5?
    Dec 2012
    Right, you still had 5 though. It's when you don't have 5, but have lower speeds is where I was starting to wonder.
    Sold.
  9. #9 Re: AC and Heat work on settings 1-4 but not 5?
    Jun 2013
    Massachusetts
    Quote Originally Posted by blackflag View Post
    This.
    Nothing else is wrong or broken besides the radio display light which has been broken for a while now.
  10. #10 Re: AC and Heat work on settings 1-4 but not 5?
    Jun 2013
    Massachusetts
    So should I replace the blower motor resistor and go from there?
  11. #11 Re: AC and Heat work on settings 1-4 but not 5?
    Dec 2012
    Sure, unless you have a way of testing it first, that's always a good idea to save money so you don't buy unneeded parts.
    Sold.
  12. #12 Re: AC and Heat work on settings 1-4 but not 5?
    Banned
    Oct 2013
    Moorhead, MN
    That, or a faulty ignition.
  1. Radio, heat and mpg display dont work *HELP*
    By NoIdea in forum Audio, Security & Visual Electronics
    Last Post: 03-22-2013, 07:19 PM
  2. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  3. '04 GTP No Heat (Blower & Temp Guage work)
    By tinaolszewski in forum General Tech Discussion
    Last Post: 10-10-2012, 03:36 PM
  4. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  5. Possible reason heat doesnt work? Need opinions.
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-23-2008, 12:57 PM
