Thread: boost leak/ vac leak
Results 1 to 15 of 15
  1. #1 boost leak/ vac leak
    Jun 2012
    Southern NJ
    I have my scangauge set to boost and on a 3.4" pulley, it's saying I peak at 7.1
  2. #2 Re: Accuracy of scangauge II boost reading?
    Jun 2012
    Southern NJ
    I'm thinking maybe the boost bypass valve isn't closing?
  3. #3 Re: Accuracy of scangauge II boost reading?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Whether the bbv is the problem or not, it is not the gauge's fault lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Accuracy of scangauge II boost reading?
    Jun 2012
    Southern NJ
    Quote Originally Posted by ILoveGM View Post
    I figured it was right, but I sealed everything good when I put this thing back together. I'd have a hard time believing that it could be anything but the BBV.
    Anybody have the write up with pics? ZZP has the write-up, but the pics have vanished.
  5. #5 Re: Accuracy of scangauge II boost reading?
    Jun 2012
    Southern NJ
    Or uh.. it could be that when I removed EGR I used a nickel and nothing else to seal up the port on the intake manifold.. I guess it could be leaking there.
  6. #6 Re: Accuracy of scangauge II boost reading?
    Jun 2012
    Southern NJ
    Anyone else have thoughts on boost leak?
  7. #7 Re: boost leak/ vac leak
    What other mods do you have?
  8. #8 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    S1X Cam, SSAC headers, custom CAI, 3.4" pulley with Intense MPS.. the usual stuff on a 3.4" build.
  9. #9 Re: boost leak/ vac leak
    I'd check out your egr to make sure it's not leaking
  10. #10 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    Yeah, first step was to go ahead and seal that ****er up gudentite and see if I get regular vacuum and boost back. If not, it's onto my BBV. If it's still ****ed after all that I'm going to curl up into the fetal position and cry.
  11. #11 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    Well, I went out there, started it up, let it idle, it was at -8.5 bst, and gave everything under vacuum a good little shot of brakleen but it had no effect, not even on the EGR blockoff I made. Shot a little into the intake to test it and it revved up, so I know that it's at least doing something, but everything else seems to be sealed up tight. I haven't yet tested blocking off the BBV, but would that cause a vacuum leak? Other than that I'm out of clues.
    Any help?
  12. #12 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    Well, I hooked it up to an actual vacuum gauge and it was reading -17 to -19 which is normal, so now I'm thinking it's probably just a boost leak. What's the best place to start hunting for something like that? Faulty bbv? Faulty Map?
  13. #13 Re: boost leak/ vac leak
    Unhook the vacuum to test your BCS and you'll know quick if your bCA is working properly.
  14. #14 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    Which lines do I pull to test this, and why will I know "quick" if it's working? C'mon old bill, you gotta show me the ropes here, I'm not a rocket surgeon.
  15. #15 Re: boost leak/ vac leak
    Jun 2012
    Southern NJ
    Well, it's not as bad as it seems. I guess maybe I wasn't watching the scangauge carefully last time. Took her for a run this morning and after she was all warmed up I put the hammer down. Peaked at 9.2psi boost.
    Still a little low though, isn't it? I mean I have a 3.4" pulley and shouldn't that be near 11lbs?
  1. 98 gtp boost reading
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2017, 06:38 PM
  2. Scangauge 2 vacuum reading
    By charlie31603 in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2012, 10:10 AM
  3. stock boost gauge not reading
    By mtz956 in forum General Tech Discussion
    Last Post: 10-14-2010, 08:29 AM
  4. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  5. No boost reading..
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2009, 07:53 PM
