Thread: coolant
Results 1 to 19 of 19
  1. #1 coolant
    GT Level Member 99GTRED's Avatar
    Oct 2011
    Grand Rapids, Michigan
    whats the best coolant to buy for my 06 gt supercharged? im going to flush all the sh1tty dexcool out soon
    99' GT: CAI, exhaust, 110k, totaled
    06' GP GT Supercharged, 89k, sold
    11' Scion tC: DD
    99' Trans Am WS6
  2. #2 Re: coolant
    Whatever's cheapest
  3. #3 Re: coolant
    cheap store brand is fine. get a gallon of straight antifreeze, (its all you need) not the 50/50 pre mix crap. what a waste of money that stuff is.
  4. #4 Re: coolant
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    zerex g-05
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  5. #5 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    I switched to Prestone.
  6. #6 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    Gotta get more than a gallon. 12 quart capacity.
  7. #7 Re: coolant
    Quote Originally Posted by Thompsju View Post
    trust me, one gallon of straight antifreeze is plenty, one gallon is 1/3 of the coolant systems capacity.
  8. #8 Re: coolant
    Dec 2012
    Where 4T65E's were born
    I bought two gallons(8 quarts) of the "cheap stuff" green conventional antifreeze, added exactly 6 and the system was full. Beforehand the system had pure water from a flush, so it's nearly exactly 50/50.
    Sold.
  9. #9 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    Except you shouldn't run less than 50/50 in cold environments, and it's almost November.
  10. #10 Re: coolant
    Dec 2012
    A 70% water, 30% antifreeze can go down to about 0° F according to a tester I've got. My friend used 50/50 as if it was pure and got that ratio(on his car). That's not very good protection though. 50/50 is what's recommended, and you can go as high as 70% antifreeze and 30% water.
    Sold.
  11. #11 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    Well "below zero" is common here. I think we hit -36 in February.
  12. #12 Re: coolant
    you can buy a antifreeze tester for about 5 bucks still. it will tell you how cold your coolant is good for the way its mixed in your rad.
    i do the one gallon of coolant and fill it the rest of the way with water. it gets to around zero degree's ( water freezes at 32 deg's so cold) here in the winters and the rad is always green liquid. no slush ever.
  13. #13 Re: coolant
    Dec 2012
    The lowest I can ever remember getting to in warren is like 12 degrees, it could have gotten colder here in my lifetime but I don't remember it. All it takes is some wind on those days, and high school was cancelled. And the tester he's talking about is what I used. (the cheapie ones with the ball or little floating needle). I've used spectrographs to measure the freezing point before, but they're not so cheap. Probably more accurate though.
    Sold.
  14. #14 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    Well the recommendation is 50/50, he lives in Michigan, and it's a thread started by him about his car. Lol. 50/50.=)
  15. #15 Re: coolant
    back of the gallon of antifreeze also has a chart on it telling your what mix ratio give you what temp that you can be safe at.
    http://www.magers.org/handy/antifreeze.html
  16. #16 Re: coolant
    Banned
    Oct 2013
    Moorhead, MN
    Just as your owners manual tells you how to service you own vehicle, eh?
  17. #17 Re: coolant
    Dec 2012
    Yes so do I, 50/50 is the key, and any pure green coolant will do lol. Universal will work too, I was going to use it in mine, and upon posting that I got raged at just to use green so I did.
    And wow, my tester must be accurate. I mentioned it said 4 quarts in a 12 quart system would be good til 0°F, the chart shows exactly that. Cool, I guess I'll keep it around lol
    Sold.
  18. #18 Re: coolant
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    When I replaced the radiator I flushed the block like crazy, then filled it with as much of a gallon of conventional green as it would take, then filled the rad with the rest, then topped it off with water. 50/50 then went into the overflow bottle, which emptied itself twice and had to be refilled before all the air finally got out of the system. I'm probably somewhere around 40% at this point, which is more than enough for southern Ohio.
    Next spring I'll flush the system again, because I know there's still remnants of Dexcool in the block that I'll never fully get out.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  19. #19 Re: coolant
    Dec 2012
    If you flush each component individually, you can get 100% of it out.(Coolant, not sludge) (Engine, Radiator, Heater core) I'd flush with full pressure from the garden hose, backwards and forwards for at least 30 seconds each. That's a lot of pure water to run through it. The radiator is the most important to backflush. Putting the hose in the top, a lot of the water may go through the bottom half of the tubes, whereas putting it in the bottom, the water is forced to fill it up, then go out the top.
    This is a pretty often asked about topic, I'm making a video when I flush our impala's system again.
    Sold.
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
