Thread: Squeaky sound coming from the front somewhere?
Results 1 to 14 of 14
  1. #1 Squeaky sound coming from the front somewhere?
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    When i turn I kind of hear a sqeaky sound coming from the front somewhere. Kinda hard to describe what it sounds like, but think of it where your in an old recliner chair going back and forth making a noise, thats what it sounds like to me. I know my serpentine belt is going bad and needs to be replaced, but what could it be? I just started hearing it.
  2. #2 Re: Squeaky sound coming from the front somewhere?
    Dec 2012
    Where 4T65E's were born
    Strut mounts. You only hear it while turning the steering wheel, right? Mine do the same.
    Sold.
  3. #3 Re: Squeaky sound coming from the front somewhere?
    Jun 2013
    Illinois
    I believe so yes, you get the sound im describing? Is this bad?
  4. #4 Re: Squeaky sound coming from the front somewhere?
    GTX Level Member blackflag's Avatar
    Virginia
    i drove for about 5k miles out of laziness. you should change them though asap
  5. #5 Re: Squeaky sound coming from the front somewhere?
    Jun 2013
    Illinois
    Is it a tough job? What parts are required?
  6. #6 Re: Squeaky sound coming from the front somewhere?
    Virginia
    spring compressor and basic tools
  7. #7 Re: Squeaky sound coming from the front somewhere?
    Virginia
    might as well get gr-2's and eibachs since your car is most likely 10 years old........
  8. #8 Re: Squeaky sound coming from the front somewhere?
    Dec 2012
    I've been driving on noisy strut mounts forever. All stock struts will do it by like 100k miles, and people go pretty far on stock struts. I don't really notice it on my car unless I stick my head out the window and turn. My struts are bad though, they also squeak when they're compressed quickly, like hitting a decent sized bump. I'll get some stock replacement kyb's eventually.
    Sold.
  9. #9 Re: Squeaky sound coming from the front somewhere?
    Jun 2013
    Illinois
    Are those really needed? Its a 99, with about 134000 miles, Dont want to throw alot of money at it since Ill most likely be getting a new car after winter
  10. #10 Re: Squeaky sound coming from the front somewhere?
    Dec 2012
    If you want a good stock replacement, get 2 of these: http://www.amazon.com/KYB-SR4002-Str...eywords=SR4002
    Sold.
  11. #11 Re: Squeaky sound coming from the front somewhere?
    Jun 2013
    Illinois
    Thats the complete assembly?
  12. #12 Re: Squeaky sound coming from the front somewhere?
    Dec 2012
    Yes, 3 bolts on top and two at the bottom and they swap out. Everything's new.
    Sold.
  13. #13 Re: Squeaky sound coming from the front somewhere?
    Jun 2013
    Illinois
    Sounds tempting, found a good write up though. http://www.gpona.com/forums/suspensi...-s-t12932.html
  14. #14 Re: Squeaky sound coming from the front somewhere?
    Dec 2012
    You can use it if you want for installation and removal, but it appears that he is re-using the spring, whereas the struts I posted are complete, so ignore that. It's really quite easy. As long as you have an impact gun, or a decent breaker bar, there's nothing standing in your way. Of course an alignment afterwards is necessary since that is your camber adjustment. If you have other suspension parts to replace that affect alignment, replace them too.
    Sold.
  1. Squeaky noise from front passenger wheel...
    By 06GXPGAL in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2013, 09:48 PM
  2. Weird sound coming from front end...
    By zql8tr in forum Brakes/Suspension/Chassis
    Last Post: 11-26-2011, 11:19 AM
  3. Squeaky sound coming from the left side of the engine bay.
    By elhomero in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 04:03 PM
  4. Weird sound coming from belts
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 10:48 PM
  5. Ping sound coming from Front end...
    By andremike in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2010, 02:19 PM
