Thread: 1998 GP Pace Car starts then stalls
Results 1 to 6 of 6
  1. #1 1998 GP Pace Car starts then stalls
    Oct 2013
    Miami
    Hello to all. I am new to the community but glad to be here. I have a 1998 Pace Car. Ran beautifully when it came off the transporter. Started up fine and ran well, after that. Put it on the highway and went 15 miles away at 65 MPH; parked. Then started right up but ran weird for a minute. Drove same 15 miles back. Started up again with no problems about 20 minutes later drove 1 mile to office and parked it there. Came back 3 days later. Starts and turns off. Fuel pump works, relay is good, fuse is good, no other work done at all. After replaced fuel filter car ran for about 2 minutes and I thought problem was solved, then it stalled. Now, starts right up and stays on for anout 10 seconds and stalls. Has anyone experienced this? I heard maybe a resistor located behind the windshield washer bottle? Could that be true? Please help. Getting frustrated. Wnat to drive this thing. THANKS
  2. #2 Re: 1998 GP Pace Car starts then stalls
    Dec 2010
    DMV
    Try unplugging the Maf sensor and see does it stall
    Sent from my HTC One using Tapatalk 2
  3. #3 Re: 1998 GP Pace Car starts then stalls
    Oct 2013
    Miami
    Will do. Thanks
  4. #4 Re: 1998 GP Pace Car starts then stalls
    sounds like the high speed fuel resistor is going bad.
    try this, if it works the resistor is bad, and yes its in the fender by the battery.
  5. #5 Re: 1998 GP Pace Car starts then stalls
    Oct 2013
    Miami
    yes, bent tab 85 back and the car ran without an issue. So I traced what I feel is like the plug for the actual resistor. Traced the wire down past the fender well and it ended up located just inside the right front (passenger) wheel. Looks like a small black horseshoe looking thing with what appears to be a white connector. I separated it out once and reconnected and still would not start so then I did what you said and the car started and ran. So my question is do you know if what I just described is in fact the resistor that is giving me a problem or do you have another helpful photo. Thanks.
  6. #6 Re: 1998 GP Pace Car starts then stalls
    heres a how to for the resistor change. http://rmcgp.clubgp.com/fpresistor.html
    i know its the right thing to fix it. but people have left it like this for years on end with no problems. so theres no rush to get it fixed.
  1. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
  2. Car starts, but stalls
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-06-2011, 03:35 PM
  3. 00 GT Starts then stalls?
    By dynamicyaz in forum Introductions/Noob Questions
    Last Post: 04-13-2010, 03:08 PM
  4. Car Starts and Stalls
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 09:40 PM
  5. Car starts, bogs down and then stalls.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 01:54 PM
