Thread: RPM Jerk, no codes
Results 1 to 10 of 10
  1. #1 RPM Jerk, no codes
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    So when im cruising at a relatively high speed or if im on the highway around 25-2700rpms, they will jerk slightly and it will jerk the car almost like the engine is failing for half a second, it will do it a couple times slowly or a little more times faster, my friend said it could be since i have a K&N CAI, it would be dirt getting sucked in and hitting the MAF and causing the jerk but I'm not sure about that, maybe? and another guy said it was the torque converter, but my thought is it needs new fluid in the tranny, any other diagnosis's? thanks guys
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  2. #2 Re: RPM Jerk, no codes
    Mar 2013
    Fort Lauderdale, FL
    NOTE: it doesn't happen all the time, just here and there but its obviously not normal
    1998 GTP Loudmouth
  3. #3 Re: RPM Jerk, no codes
    Clean the MAF first. Might be dirty.
    The torque converter still might be the cause, kinda just guessing right now though.
  4. #4 Re: RPM Jerk, no codes
    Dec 2012
    Where 4T65E's were born
    When you say the RPM's jerk, do they go up or down?
    Sold.
  5. #5 Re: RPM Jerk, no codes
    Mar 2013
    Fort Lauderdale, FL
    I have already cleaned MAF, and the rpm's jerk down like 100 and go back up within a second but it occurs more than once, my buddy said it might be fuel related
    1998 GTP Loudmouth
  6. #6 Re: RPM Jerk, no codes
    I've seen it be a bunch of things. Downside is you can't pinpoint anything. Before you blame trans etc, shotgun coils and icm at it as well as cleaning the maf etc.
  7. #7 Re: RPM Jerk, no codes
    Mar 2013
    Fort Lauderdale, FL
    This is kind of a hard question to answer but her you seen many people with this same problem being transmission related?
    1998 GTP Loudmouth
  8. #8 Re: RPM Jerk, no codes
    my regal was having the rpm's jump around, in 3 rd gear only, and at 30 to 40 mph at light throttle only. a month later i lost 3 rd gear.
  9. #9 Re: RPM Jerk, no codes
    And my Regal was jumping 1k every so often, oddly upward as if 4th gear was kicking out. Ended up being a coil pack. More than you'd expect the issue is ignition related (tb, maf, wires, plugs, coils) than trans.
    Not sure about you, it's much easier for me to shotgun some ignition stuff than swap a trans.
  10. #10 Re: RPM Jerk, no codes
    Mar 2013
    Fort Lauderdale, FL
    It is the same for me, but mine doesn't jerk 1k rpm's, just 100 a couple times then It will stop
    1998 GTP Loudmouth
  1. jerk or shudder sometimes when sitting at stoplight?
    By davidadams in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2014, 07:09 AM
  2. Creak and a jerk.
    By mteschGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2012, 06:23 PM
  3. got some codes need help
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 06:20 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. road rage jerk having a bad day.
    By BlackGT97 in forum The Rant Forum
    Last Post: 09-25-2011, 06:56 PM
