Thread: Strange noise when reversing. What could it be?
Results 1 to 14 of 14
  1. #1 Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
    Hey guys, recently my 2000 Grand Prix GTP started making a strange noise when I reverse and the wheel is turning all the way to the left. It sounds like the tire is scraping/rubbing on something. It only happens when I reverse and turn the wheel left, when I turn the wheel right it doesn't make the noise. Is this a common issue or has anyone else experienced this? The tires are fairly new, I got them this February and they are the recommended size. Thanks for any help.
  2. #2 Re: Strange noise when reversing. What could it be?
    SE Level Member stockGTforlife's Avatar
    Aug 2013
    Alliance, Ohio
    I had that same thing happen to my buddies saturn. it turned out to be a messed up tie rod in my case
    97 Grand Prix GT- Will be missed...
    04 Monte Carlo Supercharged SS- Bone stock.....for now
  3. #3 Re: Strange noise when reversing. What could it be?
    St. Louis
    Turn it all the way to the left and stick your head under there and look. If something is rubbing then you should be able to see it. Look for a clean spot on the plastic wheelwell area, or anything metal under there. If it's shiny, then there's your rub.
  4. #4 Re: Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
    So I found the issue... here's a pic. Is this any easy fix? Also, it's starting to make a rattling sound now when I drive and go over somewhat of a bump.
  5. #5 Re: Strange noise when reversing. What could it be?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    What's your rim setup? You could prolly just throw on spacers and call it a day if your aftermarket, but you shouldn't have rub with stock rims if you do something's wrong
    Sent from my iPhone
    2004 Grand Prix GTP 150,000 " The New Edition "
  6. #6 Re: Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
    Everything is stock.
  7. #7 Re: Strange noise when reversing. What could it be?
    Oct 2012
    Philadelphia
    What's your tire size?
    Sent from my iPhone
  8. #8 Re: Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
  9. #9 Re: Strange noise when reversing. What could it be?
    St. Louis
    I just looked at my 00 GPGT and that splash shield on mine has the bottom edge tucked up on TOP of the subframe, not hanging below it like on your pic. I'd bet that's why you're rubbing.
  10. #10 Re: Strange noise when reversing. What could it be?
    yeah i think that the lower part should be behind the sub frame there, you should be able to see the lca mounts. i cant see yours due to it being covered.
  11. #11 Re: Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
    FordMan77 could you post a pic of yours please?
  12. #12 Re: Strange noise when reversing. What could it be?
    St. Louis
    Here you go...
  13. #13 Re: Strange noise when reversing. What could it be?
    Sep 2013
    Boise, ID
    Thank you! Mine's all out of whack compared to yours. I wonder what could have caused it.
  14. #14 Re: Strange noise when reversing. What could it be?
    A technical difficulty.. lol
  1. Strange engine noise
    By alvaradoguy2002 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-19-2012, 11:29 PM
  2. Yet another strange noise question!
    By JackSharp in forum General Tech Discussion
    Last Post: 01-03-2012, 11:55 PM
  3. 2005 GTP strange noise when reving the motor
    By starscream5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 06:53 PM
  4. Strange Noise from Driver front wheel area
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2011, 05:36 PM
  5. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
