Thread: Issues with 2nd axle in 6 months
Results 1 to 16 of 16
  1. #1 Issues with 2nd axle in 6 months
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    i have a 1998 gtp and i replaced my passenger axle back in may and just did once again in august. now the one i just put in has yet had a boot failure like all the previous ones put in. i have no idea what is causing the boot failure, nothing is contacting it nor improper installation. i'm tired of putting them in. any suggestions on why it keeps blowing the boot apart?
    this is the axle i put in with my father who is a tier 4 master mechanic,
    MasterPro® CV 60-1256 - CV Drive Axle | O'Reilly Auto Parts
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  2. #2 Re: Issues with 2nd axle in 6 months
    there was a thread about the bellows in the boots, i cant remember if it was the more or less bellows were better. but one of them fell of more often or something like that.
    i used a napa axle, no problems so far 2 years later now.
  3. #3 Re: Issues with 2nd axle in 6 months
    May 2013
    well i have been doing warranty exchanges and i have no issue getting another just getting tired of doing it. this one has more bellows which i read was better.
  4. #4 Re: Issues with 2nd axle in 6 months
    St. Louis
    Yep, go with the Napa axle from now on. Sure, you can keep exchanging them from OReillys, but as you said you're tired to swapping axles.
  5. #5 Re: Issues with 2nd axle in 6 months
    May 2013
    my main question isn't about quality I just want to know if there would be any other reasons to cause it other than just being from o'reilly or not
  6. #6 Re: Issues with 2nd axle in 6 months
    I live here. DirtDog's Avatar
    Jun 2012
    The more the better. I had one that had less and it only lasted 3 months. Current one has several more than old and its much better
  7. #7 Re: Issues with 2nd axle in 6 months
    May 2013
    its breaking at the cup, there are only 3 bellows but that's the only setup I have found 5 on the hub side and 3 on the cup side
  8. #8 Re: Issues with 2nd axle in 6 months
    May 2013
    any one use a split boot before?
  9. #9 Re: Issues with 2nd axle in 6 months
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Check your motor mount, a failed one can cause improper geometry, a good vibration and the boot popping off.
  10. #10 Re: Issues with 2nd axle in 6 months
    May 2013
    I was going to replace it but im not sure if its bad. I just was going to incase it was the problem the next time I put a new axle in.
  11. #11 Re: Issues with 2nd axle in 6 months
    Dec 2010
    Wesley Chapel, Fla
    The same thing happen to me, at 130k my right oem one went out, got a replacement from pepboys
    a month later i notice grease on rim, they gave me another one about 3 weeks later same problem
    took it back got a refund and got one from napa since than no problems Knock on wood, just
    turn 168k.
  12. #12 Re: Issues with 2nd axle in 6 months
    gardner,mass
    Do yourself a favor if you do plan on replacing mounts. Do not buy cheap mounts form you local auto parts stores. Most carry anchor. These mounts are garbage. They are ok for the average low hp dd civic or w/e but for our cars ive blown out 3 trans and motor in a few months. Buy a polly mount from zzp or make your own if you can. Dealer price is like 120 or something so you might as well get polly.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  13. #13 Re: Issues with 2nd axle in 6 months
    May 2013
    well thanks guys and my father deals with O'reilly on a daily basis so he and the regional manager had a few words and now they are giving me a new axle not rebuilt and if this one blows they are going to pay for one from where ever i want.
  14. #14 Re: Issues with 2nd axle in 6 months
    May 2013
    checked the mounts and found my receipt on the motor mount its a anchor mount. It hasn't collapsed yet, so any other ideas on issues that would cause it? I don't want to put it in until I have found the reason of failure. I doubt its just been p.o.s. half-shafts
  15. #15 Re: Issues with 2nd axle in 6 months
    May 2013
    bump
  16. #16 Re: Issues with 2nd axle in 6 months
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    Quote Originally Posted by Ginseng View Post
    atleast it was your motor mounts over and over, I somehow with a 3.4 setup managed to dent the subframe and twist the metal bracket on the engine after a launch from a stoplight one night
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  1. 5th Bad Axle in less than 6 months . . .
    By fisher580 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2013, 10:34 PM
  2. MAF going bad after just 8 months??
    By thegipper in forum General Tech Discussion
    Last Post: 11-02-2012, 12:15 PM
  3. 3 CVs in 2 Months?
    By Kasey in forum General Tech Discussion
    Last Post: 06-03-2011, 09:56 PM
  4. Bad 3 Months
    By EJOUIE in forum The Rant Forum
    Last Post: 06-05-2010, 12:42 AM
  5. What to Do? Old Gas - Car Sat for 18 Months
    By TommyGloves in forum General Tech Discussion
    Last Post: 05-21-2008, 07:17 PM
