Thread: So I found a GTX...
Results 1 to 20 of 21
  1. #1 So I found a GTX...
    Nov 2011
    Omaha, NE
    The guy is asking 2500 and it all seems to be in good shape. Has 160k on it and the guy claims it has no rust and that the transmission and everything else is great, even has a new radiator, sway bar, tie rods, and alignment. So I'm telling myself holy crap I need to get this thing. So I text him and stuff all day and then tonight he tells me when I call him that it's not supercharged. So I'm left sitting here wondering what the hell? Where do I go from here? I was dead set on buying this thing because I can never find GTX's but it's not supercharged so I just don't see the point....am I crazy?
  2. #2 Re: So I found a GTX...
    Dec 2008
    Lawndale, CA
    You could always top swap it.
  3. #3 Re: So I found a GTX...
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    top swap!!!!!!!!
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  4. #4 Re: So I found a GTX...
    Top swap can easily be done for under $600. I always thought it was dumb the guys that did that stuff to GTs, but eh, it was mostly a cosmetics thing anyway.
  5. #5 Re: So I found a GTX...
    Nov 2011
    Omaha, NE
    I like the top swap idea but I was reading around and I have heard horror stories of them blowing up within 1000 miles of being built.
    How much would the turbo route be?
  6. #6 Re: So I found a GTX...
    Swap a complete motor then
    04 Comp G.
  7. #7 Re: So I found a GTX...
    Nov 2010
    Ray MI
    I have seen a GTX that was just a 3800. They are out there.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  8. #8 Re: So I found a GTX...
    Ohio
    GTX was just an exterior package.
    You could have them install the slp performance package while it was getting the exterior mods done. But it wasn't part of the deal.
  9. #9 Re: So I found a GTX...
    ^There were actually stage kits in the later years, stage 1 being just cosmetic stuff, stage 2 being the ram air intake and exhaust, stage 3 was for gtps only and included rockers and a 3.5 mps. So you can probably easily find a quite a few stage 2 GTs.
  10. #10 Re: So I found a GTX...
    Nov 2011
    Omaha, NE
    I'll just post the ad here so you guys can see what I'm looking at....
    1999 Grand Prix GTX for Sale
  11. #11 Re: So I found a GTX...
    Offer $2k cash and use the other $500 and piece together either a topswap or source a complete l67/l32
    04 Comp G.
  12. #12 Re: So I found a GTX...
    Nov 2011
    Omaha, NE
    Are the top swapped motors still ok to take down to 2.8 and such pulleys (with supporting mods) and still be just as safe as the L67?
  13. #13 Re: So I found a GTX...
    Yes, with proper supporting mods. Even the na engines have pretty solid bottom ends.
  14. #14 Re: So I found a GTX...
    Nov 2011
    Omaha, NE
    Really? Well that settles it. If the guy still has it (he said someone stopped by to look at it at six) then I shall topswap it and if it ends up blowing up after a while then an L67 shall be purchased. We will see how it all works out I guess
  15. #15 Re: So I found a GTX...
    Kansas
    Quote Originally Posted by slick2500 View Post
    I know where a stage 3 is with ~40k miles on it.
    On a side note I would be more worried about the transmission with 160k than adding more power to an already going out transmission.
  16. #16 Re: So I found a GTX...
    Nov 2011
    Omaha, NE
    Well as the mods get more and more aggressive the trans would be replaced with one of the triple edge ones. This one sounds like it will work long enough and maybe even beyond what I need it to work for.
  17. #17 Re: So I found a GTX...
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Why not just turbo it? I think if you have the money for a turbo (not sure if you do) and are gonna do the work for a topswap then just put that work towards a turbo.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  18. #18 Re: So I found a GTX...
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by SomeDudeAtHome View Post
    Basically he's saying your a poor grand prix owner and should quit while your ahead
  19. #19 Re: So I found a GTX...
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Lots of guys have high mileage transmissions with mods. Just depends on if you're stupid or not. Iceman has a VERY high mileage transmission from what he told me and he's running a smaller pulley. Not very small, but still smaller.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  20. #20 Re: So I found a GTX...
    Max Cook
    Guest
    Quote Originally Posted by ILoveGM View Post
    Yeah I wouldn't quote that as an example. He's very lucky, and it has started to die on him as well now.
    If you're gonna mod and not use it why mod? If you're gonna mod, make sure you have $$ ready for a broken trans when it happens if you're not up for doing it at the same time.
  1. Look what I found
    By DirtDog in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2012, 12:49 PM
  2. I found it!!!
    By TLSheff in forum Off Topic Discussion
    Last Post: 09-27-2011, 03:42 PM
  3. Found IT !
    By mickey t in forum Introductions/Noob Questions
    Last Post: 06-08-2009, 07:48 PM
  4. Found This Joke. Also Found It Amusing.
    Last Post: 12-05-2008, 04:25 AM
gtx
